Author Topic: Spring install  (Read 2133 times)
November 02, 2011, 10:08:38 AM
Re: Spring install
« Reply #15 on: November 02, 2011, 10:08:38 AM »
Quote from: "kchaudha"
Install doesn't look bad but how long does it take to remove the old rusted components?  Also curious on what methods you guys used.  Is penetrating oil and a breaker bar enough or did you have to use a torch and heat up the nuts?  Or did you even have to cut some bolts?
I just did my brakes recently and the most time consuming and annoying part was removing the old rusted components so that's why I ask!
Required Tools: RBFH, Sawsall with top quality Bi-metal blades, Oxy-Acetalene rig is nice if you have ne or can get your hands on it.  Oh, and a big pair of vise grips to hold the big punch while you wail on it with the RBFH  :shock:
If it's not a rusted glob of Shitz, then an impact gun works great on the bolts and nuts, takes em' or breaks em, one way or the other.
November 02, 2011, 12:18:00 PM
Re: Spring install
« Reply #16 on: November 02, 2011, 12:18:00 PM »
I replaced my spring bolts and hardware a while back...  you should have seen the mess on my shop floor!   I used a blue tip wrench to get my bolts off.  (oxy-acetylene torch)
November 03, 2011, 12:18:47 PM
Re: Spring install
« Reply #17 on: November 03, 2011, 12:18:47 PM »
Quote from: "wingtime"
Pretty much one size fits all. The torch saves a lot of time and wasted energy. It's the way to go if you have one. :idea:
