Hey Fighting Irish,Well for starters you have a classic Flatback! Not newer than 71`,72' was the first year of the V bottoms. What did she used to have for power? Twin 55 OMC's maybe? You have to cut the floor in front of the transom to allow enough access to cut out the wood core and cut where the stringers connect to the transom. You are going to find issues with wet foam in the stringer boxes that you are going to have to deal with, so be prepared for this to be a little more than just a transom job. All that wet foam needs to be removed and the stringers dryed out before you can think about reglassing them to the new transom.
