I'm sure that tabman from bennet marine will chime in soon!!
I can however verify that whoever installed your tabs did not know what they were doing and did not bother to read the instructions. When retracted NO part of the tab should be below the hull. That is causing drag and performance loss like that.
Bondobill, He is also correct in that we do make 2" shorter actuators that may make it easier to reposition them. I could also send you the parts to modify your existing actuators so that they are 1" shorter if that would help (no charge).Let me know what you think.Tom McGowBennett Marine
I thought about replacing with Lencos, but with the reliabilty and customer support you can get from Bennett why would I even consider anything but Bennetts.Bill
I'm a pleasure user but a long time ago Bennett did what every successful business strives for, that is they made me a customer for life. Their continued support substantiates my choice but based on my research and opinions on both products posted here and within other forums, I think you will be pleased with either one. As stated, I'm a Bennett guy. Your mileage may vary.Good luck.
