Author Topic: quick question(s)  (Read 639 times)
April 11, 2011, 07:05:59 AM
Read 639 times
catndahats
quick question(s)
« on: April 11, 2011, 07:05:59 AM »
Still looking for a project...now waiting on a call back.  Got a lead, but don't can't tell much from the one photo.  Don't have year or model infor except the person says it is "20 feet"....
Questions:
* What is the difference in the early 19'6" hull and the later '70's 19'6"?
* Is the later 20ft. hull the same with just a different design deck cap?
* I really like the flat lines of the pre 1975 hulls and flat deck, has anyone ever removed the raised deck and rebuilt the boat with a custom/flat deck that follows the shear/rub rail lines of the hull?
Thanks in advance for reading for my 5am wonders!
Gotta get to work, but will check periodically...may be a good lead, may be a dud.
Nate :?:
April 11, 2011, 11:26:32 AM
Skoot
Re: quick question(s)
« Reply #1 on: April 11, 2011, 11:26:32 AM »
1. Higher gunnel / Taller cap and the interior gunnels are not recessed in the later 70's models
2. Basically.  The Cap and finished interior gunnels are the main differences and I think the center console doesn't flip down in the late 70's
This ad is of an early 80's, which should be the same as the later 1976 and beyond - 19-6's .  You can notice the taller cap (from rub-rail about 4-5" taller) Its a bit harder to notice the interior gunnels on the 19-6, but you can see it clearly on the 17. (basically same layout)
http://www.classicaquasport.com/gallery ... 572/page/1
1975 19-6 - 90hp Tohatsu
April 11, 2011, 08:22:36 PM
catndahats
« Reply #2 on: April 11, 2011, 08:22:36 PM »
Thanks!  All my questions were for naught this time....seller disappeared, ad cancelled, won't return calls.
Getting ready to make another cast.....more than one fish in the sea.
