Author Topic: 225 Gauge panels- Before & After  (Read 2130 times)
April 08, 2011, 11:21:31 AM
Read 2130 times
Glock Diver
« on: April 08, 2011, 11:21:31 AM »
Cross off another "TO-DO" from my list.  Thanks to some help from Flounderpounder225, I have 2 sweet looking new items on my helm:
BEFORE
[/color]
AFTER
[/color]
No more cracked corners and faded coloring.  Plus I like having the glove box door black instead of clear.  No need for people to see what's in there.  And having it match the gauge panel is even better.
Marc- thanks again bro.  The water pressure gauge doesn't seem compatible for some reason.  On the back, there is a small metal tube protruding from the gauge, and my old gauge didn't have this.  When I tried to connect the tube to the new gauge, it wouldn't fully seat onto this port, because of the tube.   But thanks anyway!   :thumright:
April 08, 2011, 12:09:46 PM
Re: 225 Gauge panels- Before & After
« Reply #1 on: April 08, 2011, 12:09:46 PM »
Mike,
All WP gauges have a small nipple on the back side to connect the hose to.  Sticks out the back maybe 1/2".  Is this what you are talking about?
BTW, that looks AWESOME! :salut:  :salut:
April 08, 2011, 12:16:16 PM
« Reply #2 on: April 08, 2011, 12:16:16 PM »
glad it all fit, having the same model boat and size of panels made it pretty easy to duplicate and have a reasonable degree of certainty that it would fit correctly. Pass the water pressure gauge on to someone else, if you can't or don't care to use it, I don't need it back.  :cheers:
April 08, 2011, 06:21:01 PM
Glock Diver
« Reply #3 on: April 08, 2011, 06:21:01 PM »
Mike,
Yep.  My existing gauge didn't have that nipple, but the replacement does.  I wonder if it would work if I cut it off?
April 09, 2011, 12:10:16 AM
« Reply #4 on: April 09, 2011, 12:10:16 AM »
Quote from: "Glock Diver"
Mike,
I have never seen one personally, but it sounds like your old WP gauge was totally electrical with some type of sending unit in the powerhead.  Otherwise, the only way to receive water pressure at the gauge is through a physical hose attached to the "nipple" that is on every gauge I have ever seen???  :scratch:
April 09, 2011, 08:59:38 AM
« Reply #5 on: April 09, 2011, 08:59:38 AM »
I've never seen a water pressure gage without a nipple. Are you sure your not confusing it with a temp gage? Can you take a picture of the nippleless gage?
April 09, 2011, 12:03:09 PM
DOCREED
« Reply #6 on: April 09, 2011, 12:03:09 PM »
Looks better than new.
89 250 CCP
full transom
April 09, 2011, 09:17:50 PM
« Reply #7 on: April 09, 2011, 09:17:50 PM »
nice!!! :salut:
April 09, 2011, 09:38:55 PM
Glock Diver
« Reply #8 on: April 09, 2011, 09:38:55 PM »
Thanks fellas, it does look like a factory job, huh?  :cheers:
About those water pressure gauges.  Here's a pic of my OLD gauge (no nipple on the post):
And here's a picture of the NEW gauge (with a nipple, and you can see my tube also).  I wonder if I get a new fitting for the end of that tube, would this gauge work?
April 09, 2011, 09:55:11 PM
« Reply #9 on: April 09, 2011, 09:55:11 PM »
How big is that tube,from the pic it looks like you just need to cut that fitting off and shove it on the nipple,mine is setup that way then add a hose clamp.
April 09, 2011, 10:59:35 PM
« Reply #10 on: April 09, 2011, 10:59:35 PM »
Mike,
Your old gauge used a compression nut, simalar to the fittings on a Bennett trim tab pump...
April 17, 2011, 10:22:34 PM
Glock Diver
« Reply #11 on: April 17, 2011, 10:22:34 PM »
Welp, I just took the hacksaw to that nipple, now the tube fits right on this gauge. Maybe Wednesday I can run the motor on the earmuffs and see if it works.  :thumleft:
But when I ran out yesterday for the first time since disconnecting and reconnecting my gauges in the new panel, I experienced a strange beeping noise, similar to the low oil alarm, but not as loud. But no lights lit up at all, and I had plenty of oil, and no way was I overheating right away. Could I have connected some wire wrong?
Didn't affect performance at all, but it was a constant, low beep the entire day.  :scratch:  Anyone know if there is a water pressure alarm?
April 27, 2011, 11:07:31 PM
Glock Diver
« Reply #12 on: April 27, 2011, 11:07:31 PM »
My nipple problem is fixed!
Always wanted to say that.  <!-- s:D -->:D<!-- s:D -->  anyhow, Marc's replacement water pressure gauge works fine, once I cut off the extra, unneeded nipple.  I'm getting 5-15 psi readings on the gauge.  I guess that's normal?  First time I've had a working pressure gauge.
thanks again Marc!
Now I just gotta figure out which gauge I reconnected incorrectly to give me the annoying beeping. Will investigate tomorrow on the trailer, thanks to a SCA...
April 27, 2011, 11:53:29 PM
« Reply #13 on: April 27, 2011, 11:53:29 PM »
Good job Mike,can't wait to see all your upgrades next weekend at the gathering.
April 28, 2011, 12:56:10 PM
« Reply #14 on: April 28, 2011, 12:56:10 PM »
Mike, big difference, looks great!
I'd like to thank you for taking the time to take and send those pics of instruments and panels when you were at Marine Liquidators. They had great prices, will be using them. Thanks again...and ya'll have a great time camping!
