Author Topic: My garage DIY anchor project...  (Read 2443 times)
April 02, 2011, 01:26:40 PM
Read 2443 times
Glock Diver
« on: April 02, 2011, 01:26:40 PM »
Well, after losing 2 anchors in 2 weekends, I decided I'm done buying anchors!  My new policy:  I'll use anchors that I find while diving, or I'll make them.
So, here's my take on a Mighty-Mite grapple anchor knock-off.  Cost me about $25 in materials to make it.
If you like it, there's detailed instructions on how to make one here: http://www.thehulltruth.com/boating-for ... tures.html
April 02, 2011, 03:10:06 PM
Re: My garage DIY anchor project...
« Reply #1 on: April 02, 2011, 03:10:06 PM »
very nice!
April 05, 2011, 12:47:01 AM
seagate
« Reply #2 on: April 05, 2011, 12:47:01 AM »
put a ring on the top where the hooks are and put your shackle ,chain and rode there then take a zip tie and run it to your top ring, zip tie chain to your ring when you anchor if you get stuck just pull line tight then snub line to cleat pull forward till zip breaks and pull the rest up.I haven't lost a anchor in a long time.
April 05, 2011, 02:38:36 PM
« Reply #3 on: April 05, 2011, 02:38:36 PM »
Similar to this but different type anchor.
viewtopic.php?p=13038#p13038
JJ
April 05, 2011, 04:41:01 PM
« Reply #4 on: April 05, 2011, 04:41:01 PM »
:wink:
April 05, 2011, 04:42:14 PM
« Reply #5 on: April 05, 2011, 04:42:14 PM »
I have revised mine now, well, when I still had the 22-2.  I switched from chain to 1/4" SS cable.  The flukes don't get hung on the cable.
April 05, 2011, 05:25:09 PM
seagate
« Reply #6 on: April 05, 2011, 05:25:09 PM »
I use a grapnel anchor like the first one never had the problem with chain.
April 05, 2011, 10:09:47 PM
Glock Diver
« Reply #7 on: April 05, 2011, 10:09:47 PM »
Quote from: "seagate"
My fluke anchor is set up this way, but my new grapnel anchor has aluminum tines, so it will bend straight if it gets hung up.
My anchor losses were somewhat unusual:
1st, the shackle either broke or the pin came out. And away we floated!
2nd, we were diving, and the current picked up so strong that I couldn't safely retrieve the anchor from 100' down, so I tied it off to a buoy float, with the intent to return the next day and retrieve it. But the current sucked my buoy below the surface, and it was GONE.
April 05, 2011, 10:38:54 PM
« Reply #8 on: April 05, 2011, 10:38:54 PM »
Mike sounds like you need a anchor retrieval ball,i don't leave home wthout mine.
April 05, 2011, 10:47:00 PM
Glock Diver
« Reply #9 on: April 05, 2011, 10:47:00 PM »
Quote from: "Circle Hooked"
Scott, that's the buoy that got pulled under the water!!!  Man was I pissed.
I had 150' of rope, 20' of chain, and we were in 102' of water. (not the recommended amount of scope, I know, but it was a galvanized grapple anchor, and the first diver secured it when he went down).  I tied off that buoy, let it go, and under it went!   :x
April 05, 2011, 11:27:42 PM
« Reply #10 on: April 05, 2011, 11:27:42 PM »
Do you or did you have that whole system ?
April 06, 2011, 11:49:10 PM
Glock Diver
« Reply #11 on: April 06, 2011, 11:49:10 PM »
No, I just had the orange buoy.  Normally I use that buoy and 100' of floating line, and toss it off the stern as a grab-line for  divers, just in case the current has picked up.  This time I thought it would keep my anchor rode at the surface, but I was very wrong.
Never used one with the metal ring as anchor retrieval -- how does that work exactly?
April 07, 2011, 07:50:54 AM
April 07, 2011, 10:09:09 AM
« Reply #13 on: April 07, 2011, 10:09:09 AM »
saw this gadget at the Miami show,same principle,a little easier to use  "griffin clip"
I use the regular ball set up works great! :salut:
http://site.griffinclip.com/Home.php
April 07, 2011, 07:51:58 PM
bobterisch
« Reply #14 on: April 07, 2011, 07:51:58 PM »
very nice!
2002 225 Explorer
225HP 4 Stroke
