Author Topic: What's good for cleaning oil/grease smudges?  (Read 798 times)
March 18, 2011, 10:57:44 AM
Read 798 times
MarshMarlowe196
« on: March 18, 2011, 10:57:44 AM »
Just finished doing some work to the boat, and I have some oil/grease smudges here and there, mostly in the form of my fingerprints  :roll:
Anyone reccomend a cleaner?  I was thinking Simple Green...
Thanks  :salut:
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
March 18, 2011, 12:13:05 PM
Re: What's good for cleaning oil/grease smudges?
« Reply #1 on: March 18, 2011, 12:13:05 PM »
Yes Sir,
Full strength.
I use it all the time.
For stubborn stuff, mineral spirits.
March 18, 2011, 12:15:11 PM
« Reply #2 on: March 18, 2011, 12:15:11 PM »
I've had good luck with simple green.  Greased lightening is good too but you might want to dilute it a bit. Greased lightening has an acid in it so be careful with it around polish aluminum since it will etch it a bit. (it will brighten oxidized aluminum though)  As with any cleaner test it in a hidden spot first to make sure it does not discolor your finish.  Purple power is another option but it is strong stuff and I have seen it discolor paints and such.
March 18, 2011, 03:11:26 PM
TheKid
« Reply #3 on: March 18, 2011, 03:11:26 PM »
Mister Clean Magic Erasers work pretty good too. No chemicals are a plus.
And an ultra fine sanding block will work too. The brick style ones. Same concept as the eraser.
My gel is shot so I don't mind, or see, the fine scratches from the sanding block.
March 18, 2011, 05:02:28 PM
DOCREED
« Reply #4 on: March 18, 2011, 05:02:28 PM »
wd40 will act as a solvent and remove grease spots.
And, if you are very careful with acetone it will remove grease in a second.  Acetone is absorbed into the blood stream thru the skin so be careful.
89 250 CCP
full transom
March 18, 2011, 05:11:17 PM
« Reply #5 on: March 18, 2011, 05:11:17 PM »
Purple stuff is great but a little strong.
March 18, 2011, 09:21:54 PM
feeling2damgood
« Reply #6 on: March 18, 2011, 09:21:54 PM »
i like to go old school with alil dawn on a kitchen sponge. cuts grease and softens your hands at the same time.
it takes alil more muscle but wont discolor anything and cost a dollar a bottle. i keep some in my boat. use it to wash hands, mix some in a bucket to clean deck, and put alil in the bildge . works great and easy to wash off.  when i worked offshore we would dump a couple in bilge to dilute the oil and stuff before pumping it over board.
"she\'let"
1974 170 johnson 135 v4
never had a bad day fishing!!!!
