Mechanic found blown fuse. Replaced fuse and engine ran rough (just like what happened on the water). Downloaded codes from EMM were strange and DFI suspects an overheated EMM. This same thing happened to computer 6 months ago when different mechanic found clogged cooling tube. I suspect the root cause is not the computer but why the cooling tubes are becoming blocked.Anyone see this before?
The internet serves up as many opinions on this subject as Carter's got pills.This will get you started....... sorta. :| http://findarticles.com/p/articles/mi_m ... _61555469/Google is your friend.Search FICHT and go from there. More than you'll ever want to know.
I want your opinion CptBob!
Quote from: "Capt. Bob"The internet serves up as many opinions on this subject as Carter's got pills.This will get you started....... sorta. :| http://findarticles.com/p/articles/mi_m ... _61555469/Google is your friend.Search FICHT and go from there. More than you'll ever want to know. Of course I could Google and did.I want your opinion CptBob!Thanks SeaBob! That should tide me over. There are a lot of these around for cheap. I don't mind wrenching as long as it results in a reliable machine. Probably still pass on these but you never know what could come my way.Thanks again.
Thanks Bob^2 and Double Trouble.and Double Trouble..curious, do the two FICHT's hanging on your transom have anything to do with your name
