Good deal Rick. Did you know that if you pull your boat up to Ruskin they will put it on for free? I think you will like it.
Rick, We need to meet up someday and compare boats. I'd like to look at a 170 up close. Someday I will need a new project
I don't think I have the instructions anymore but maybe Rick could copy his for you. All you will need is a tube of silicone rubber sealant that Bob's recommends to use when mounting.
I´m really interested in all your results. As you know, I´ve been thinking about trim tabs. At about $400 they are not cheap. Maybe a foil is all I need.......I have no holeshot issues, but slow speed planing without burying the stern would be a plus. I believe foils can´t help you with side to side trim adjustments like tabs do. But for the price difference, I´d stick with the foil if your results are good.
I think maybe "crevice corrosion" is why they recommend the sealer. That when trapped water causes corrosion. Even stainless is subject to that. That's why one sees rust stains around stainless fittings on boats.
The 22-2 does look big for it's length. I love the high sides and wider beam. Most people think it is bigger than it really is. I suppose the tower adds to the impression.
