Author Topic: NEW TO WEBSITE-1999 Aquasport Questions  (Read 1014 times)
March 10, 2011, 12:38:12 PM
Read 1014 times
dtuck
« on: March 10, 2011, 12:38:12 PM »
I am thinking of purchasing a 1999 20 ft Aqua with 2008 115hp Evinrude E-Tec.  What would be a fair price for this boat?  I need to purchase a trailer-does anyone know how much a rig like this weighs?  What should I look for when inspecting the boat this weekend?  Boat has been sitting in the water for a # of years-I plan on bringing it to a local marina so they can rack it for me and I can do visual of hull.  Any input would be greatly appreciated. THANKS!!
March 10, 2011, 06:46:57 PM
Re: NEW TO WEBSITE-1999 Aquasport Questions
« Reply #1 on: March 10, 2011, 06:46:57 PM »
Welcome aboard dtuck   :!:  :!:
March 11, 2011, 06:45:35 AM
dtuck
20 foot WEIGHT
« Reply #2 on: March 11, 2011, 06:45:35 AM »
Does anyone have any idea of the approx. weight of a 20 foot Aqua with 115 etec evinrude.  Just a ballpark-trying to buy correct trailer for boat. Thanks :D
March 11, 2011, 06:58:29 AM
Re: 20 foot WEIGHT
« Reply #3 on: March 11, 2011, 06:58:29 AM »
What model ? A Cuddy will weigh more that a Center Console.
March 11, 2011, 07:05:31 AM
Re: 20 foot WEIGHT
« Reply #4 on: March 11, 2011, 07:05:31 AM »
Quote from: "dtuck"
Probably 2500-3000 Lbs depending on fuel and gear you are hauling, a sturdy single axle rated for 3500 would do it, but if you want to have the extra piece of mind and not worry if you decide to take a long trip, get a tandem axle, then you will have more than enough trailer to do anything you want.  Just my .02 cents.
March 11, 2011, 09:16:41 AM
dtuck
« Reply #5 on: March 11, 2011, 09:16:41 AM »
Thank you for your input on weight.  Do you all have any input on what I should be looking for when inspecting this vessel.
It is a center console 20 ft 1999 with 2008 etec 115hp?  Is 115hp be enough horsepower?  Should i worry about fuel tank?
thanks  :D
March 11, 2011, 10:14:42 AM
Re: 20 foot WEIGHT
« Reply #6 on: March 11, 2011, 10:14:42 AM »
Quote from: "dtuck"
Let's see,
A 95 20 Osprey is listed at 1935lbs without motor and sports a 56 gal tank.
A 97 is listed at 2300lbs with a 112hp motor and has a 50 gal tank.
A 2004 is listed at 2145lbs without engine and has a 50 gal tank.
So......
Your 99 should fall right around that 1950 lbs+/- then add 400 lbs for the e-tec and 300 lbs for fuel and throw in several hundred for all your "needed" stuff and guess what. 3000lbs is a very reasonable high side estimate.
That's you Marc. :thumright:
Boat's rated for 150hp. 115 should push it OK but you need to base that on your type of use.
My CCP is rated at 235hp (I think) but a 200hp pushes it real nice.
You got deep pockets then there's no problem going with a bigger motor. :roll:
Tank?
Can't remember if we have had a member who has replaced one on a 99 model. You'll need to see if it at least passes the "sniff test".
March 11, 2011, 11:27:23 AM
« Reply #7 on: March 11, 2011, 11:27:23 AM »
sniff test = no gas smell in bilge,which would indicate a leaky tank or fuel /vent line
