Author Topic: opinion on a 90hp 2 stroke on a osprey 200  (Read 845 times)
March 09, 2011, 11:07:28 AM
Read 845 times
carldoc
« on: March 09, 2011, 11:07:28 AM »
Is this enough power? I have a 150 suzuki which I think is just too heavy.
March 09, 2011, 11:12:38 AM
MarshMarlowe196
Re: opinion on a 90hp 2 stroke on a osprey 200
« Reply #1 on: March 09, 2011, 11:12:38 AM »
90HP is sufficient.  Hell, 70HP will plane these boats out.  Expect top end speeds around 35mph.
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
March 09, 2011, 11:43:08 AM
« Reply #2 on: March 09, 2011, 11:43:08 AM »
The scuttlebutt on these motors was that Mercury pushed the 10% over on the horsepower allowance and they cranked out nearly 100 hp on the dyno. You should not have a problem with this engine on a 200. Start off with a 15-17" pitch prop and see if she will turn 5500 rpm with your normal load.
March 09, 2011, 07:53:48 PM
akbridge
« Reply #3 on: March 09, 2011, 07:53:48 PM »
I think it depends on the manufacturer and prop.  It should be fine.  I have seen plenty of these boats with 115hp engines.  You may not be able to pull two skiers at a time.  But who needs to do that anyway.
March 09, 2011, 08:35:04 PM
bumpster
    • http://www.xtremeled.com
« Reply #4 on: March 09, 2011, 08:35:04 PM »
If the Zuke is a 2stroke put that on. AS rigged the 200 from the factory with a 150 Yamaha as an option. I just dont see a 90 pushing that boat to the mid to high 30's on its best day and if it did it would be at WOT. factor in almost 500# in gas plus people and assorted fishing equipment. Its gonna make for a slow boat to China.
March 10, 2011, 07:15:51 PM
MarshMarlowe196
« Reply #5 on: March 10, 2011, 07:15:51 PM »
Quote from: "bumpster"
I thought that was a "Slow boat from China"..?   :wink:
Think about the weight of these two outboards-  Depending on the year of the 90HP Merc, 265 - 305 lbs.  Suzuki DT150 (depending on the year), about 450lbs, give or take.  :shock:  What are you willing to hang on the transom to get to 45mph? What about fuel consumption?  What speed would you like to cruise at?  I'm a 30mph guy because I'm usually not in a hurry.
Not to mention, 2 stroke zukes don't have the best track record in terms of reliability.
I miss having a self-bailing deck at rest, like I did with my old 90HP.  Really your choice though.
