Lew ha recommended that we pick up for the trip a handheld digital thermometer or two. The ones at HF were 40 bucks, so thanks for the links Lew.Sure would be nice to step out of the truck and immediately and accurately check the temp on the bearings and tires. Also great for use around the house.Thanks Lew.Getting ready, gearing up.
COUNTDOWN!Scotty should be in my driveway this Friday afternoon. All the parts are here, extension housings to convert to 25" shafts are painted and curing; came out very nice. I'll hit them with 1200 grit on Thursday and wax. 2 Days to go through the engines and shaft extensions and off to Bob's on Monday morning. I'm thinking about an alternative route to Bobs to keep Scotty off of I4 downtown and associated traffic.
Thank you both so very much. It is such a great feeling having friends you can count on. I REALLY appreciate this I'm very excited. Of course, as it always happens...right when you're getting ready to leave you get real busy at work So just trying to get everything done before Thursday.Bob, they are oil-injected, the tanks are mounted on top of the motors...so we're good there.Thanks again guys, Good Lord willing, will see you soon
Scott are those larger oil tanks on those motors or are they just the little header tanks? I'm curious as to how much oil capacity they have.
Quote from: "wingtime"Scott are those larger oil tanks on those motors or are they just the little header tanks? I'm curious as to how much oil capacity they have.Bruce,He has the standard 1.3 +/- gallon oil tanks under the cowling. On the inline 3 and 4 cylinder engines this was standard. Depending on the year, you opened a door on the cowling to fill the tanks that gave you access to the filler cap and dipstick. They gave you 7 hours at full throttle before setting off the low oil alarm.
Lew has recommended that we pick up for the trip a handheld digital thermometer or two. The ones at HF were 40 bucks, so thanks for the links Lew.Sure would be nice to step out of the truck and immediately and accurately check the temp on the bearings and tires. Also great for use around the house.Thanks Lew.Getting ready, gearing up.
Quote from: "gran398"Lew has recommended that we pick up for the trip a handheld digital thermometer or two. The ones at HF were 40 bucks, so thanks for the links Lew.Sure would be nice to step out of the truck and immediately and accurately check the temp on the bearings and tires. Also great for use around the house.Thanks Lew.Getting ready, gearing up.I'll be bringing one up with me, so you won't need one on the way back down here...at least not until we get to Jacksonville. Of course, as you mentioned, they are good to have, so it is up to you if you want to pick one up.I think I'm about ready to go. All trailer maintenance is complete. Lights are working. Truck has been serviced. Just need to pack up the tools and hit the road Thursday morning!
