Author Topic: Miss Delmarva  (Read 62791 times)
April 04, 2013, 08:40:27 AM
Reply #1620
Gonzo25
Re: Miss Delmarva Pics - at last - 1973 22-2 Rebuild
« Reply #1620 on: April 04, 2013, 08:40:27 AM »
Bob you are the man...how dare anyone bring up an issue to you or not be 1000% on board with whatever you say...do they not know who they are talking to?!?!? The nerve....lol get over yourself, take constructive criticism like a man and move on
April 04, 2013, 09:01:41 AM
Reply #1621
« Reply #1621 on: April 04, 2013, 09:01:41 AM »
Alright everyone.
Please go back and re-read my post. I want this to come to a simple ending. :|
This Forum has always held to the idea that we deliver information not criticism. This thread has been different than most and at this stage of the rebuild there are some frayed nerves.
That stated, keep it within Forum rules.
April 04, 2013, 09:34:06 AM
Reply #1622
Gonzo25
« Reply #1622 on: April 04, 2013, 09:34:06 AM »
Ok...understood, and you're right...you can delete my post if you'd like
April 04, 2013, 09:49:49 AM
Reply #1623
« Reply #1623 on: April 04, 2013, 09:49:49 AM »
Just got done caulking the console door, batt switch box, footrest trim ring, and electronics box frame, before the rains come.  Used GE Almond Silicone, looks excellent.
She really came out pretty, if I do say so myself.  And, yes, I just broke my arm...
April 04, 2013, 10:03:14 AM
Reply #1624
« Reply #1624 on: April 04, 2013, 10:03:14 AM »
The end product is beautiful! :thumleft:
Should bring years of enjoyment to Scotty.
Bob, broken arm?  I hope it is not serious and that you get the medical attention you need.
April 04, 2013, 11:28:47 AM
Reply #1625
« Reply #1625 on: April 04, 2013, 11:28:47 AM »
LOL I think he ment he did it patting his back Fernando...  The end result is a top notch boat that everyone should be proud of.   Hindsight is 20/20 as they say so in retrospect some things could have been done a little differently here and there but if you ask me everyone involved did and amazing job building an amazing boat!  :thumright:
April 04, 2013, 12:26:37 PM
Reply #1626
« Reply #1626 on: April 04, 2013, 12:26:37 PM »
One thing that I thought was pretty cool, from Shakespeare, first time I've seen it.  Galaxy antennas come from the factory with the cable routed out the side of the base through a grommet.  A lot of people, myself included, pull the cable out of that hole and route it down through the open bottom of the antenna base and through the mounting base.  That left you with a grommet to put back in the hole with nothing going through it.  Now, in the little parts back that comes with the antenna, they include a black plug that fills that same hole.  Excellent idea, and really completes the clean installation!
April 04, 2013, 04:50:49 PM
Reply #1627
fishinonthebrain
« Reply #1627 on: April 04, 2013, 04:50:49 PM »
Paul, you let me know how you fix your's, and let ME know!!  This upcoming weekend...
So backlighting seems simple, but it's not.  What kind of lights?  How will they mount?  How will they secure?  So I came up with this setup.  PVC L-channel attached to the top sides of the switches with 3M 2-sided foam tape (got the good stuff, can hang 5 lbs. with it), then 2 strips of blue LEDS attached to the L-channel with the same foam tape.  Can pick up the entire switch panel by the channel, shake it, and it doesn't budge...
And the effect I want...
Think Scott will like it, and it also allows easy transferring to his new panel when he gets that fabbed.
Nice to have a "punch list", and nice to see it pared down...
Bob,
Everything looks great don't break the other arm now you won't get any more work done. lol.
What brand and model of led lights did you use for the switch panel and under gunnel lights?
1987 222CCP current rebuild.
April 04, 2013, 08:08:09 PM
Reply #1628
« Reply #1628 on: April 04, 2013, 08:08:09 PM »
Miss D is ready to go home, Scott.  Maggie has chemo in the morn, so won't be home 'til around 12.  1 PM would be good.
And, of course, don't forget the proper fundage...
April 04, 2013, 08:18:28 PM
Reply #1629
« Reply #1629 on: April 04, 2013, 08:18:28 PM »
FOTB,
The lights are basically generic, as I have found that they all come from China, they all pretty much use the same LEDs, they all use the same 3M adhesive that doesn't stick worth a crap...
What I do is first test them for about 48 hours continuous on.  I've found that if there are no LED failures in that period, they are pretty much good to go.  Very rarely have I had an LED fail right out of the box, and on rare occasions will have a failure within that 48 hours.  There are some types that are heavier in weight, those I epoxy up to the surface they're going to mount to.  The lighter ones, I use 3M 77 spray adhesive on both surfaces, cleaning the substrate with acetone before I apply the lights.  Works pretty good... :thumleft:
April 04, 2013, 11:11:35 PM
Reply #1630
« Reply #1630 on: April 04, 2013, 11:11:35 PM »
Bob,
 Farley and I will be there tomorrow at 12 noon as we agreed.
April 04, 2013, 11:17:38 PM
Reply #1631
« Reply #1631 on: April 04, 2013, 11:17:38 PM »
We shall do our damndest to be home by then...I try not to hurry things on chemo morning, but since you have already determined that 12 it is going to be, if we're a bit late, then it is what it is...
April 04, 2013, 11:26:45 PM
Reply #1632
« Reply #1632 on: April 04, 2013, 11:26:45 PM »
No prob..See you at 1 pm tomorrow.
Bruce...see you at  2-2:30  pm tomorrow.
Best to our members.
April 05, 2013, 12:04:00 AM
Reply #1633
« Reply #1633 on: April 05, 2013, 12:04:00 AM »
1 will be fine.  Look forward to seeing you and Farley...
April 05, 2013, 04:47:57 PM
Reply #1634
« Reply #1634 on: April 05, 2013, 04:47:57 PM »
left work a little early today, met up with Scott and Farley over at Bruce's shop this afternoon,
snapped this pic leaving
