I am very pleased with everything Bob. Looking forward to seeing how the speaker mounts went in. Glad you avoided drilling the knees. Weird about the difference side to side. I guess when something is forty years old there will be some craziness like that to deal with. All I can think of is an air void between the coring and the hull side... Anyhow...SWEET job. Switch panel and trim panel will be to your place in the morn Fedex. THANKS!
Something interesting today. All through this long process of deciding speakers and how to install and all that crap, I had been giving Scott measurements from the starboard side...closest to the shop, easy to hop on board, that kind of deal. So I get the starboard side complete today, now it's time to start on port. Hold the speaker up to the mounting location and...WTF? Something DEFINITELY doesn't look right here. So take some measurements. The dimension that was controlling us was the distance from the liner to the inside of the vertical face of the gunnel, since we knew the speakers would drop down further than the gunnel.Well, Scott, it's a goddam good thing I WAS using the starboard side! Distance from the liner to the gunnel, starboard side? BARELY 6 1/4". Same distance, port side? 7"!!! That's like a frickin mile! You'll also notice a portion of the "knee" on the port side that isn't visable on starboard. Normally, this type of "skewing" between the liner, the hull, and the deck would basically have gone un-noticed, and, in fact, while in the boat, none of this can be seen...not even the speakers. But when one is working all afternoon in those exact areas...well, let's just say I was a bit taken aback...If I had been using the port side to give him dimensions, well, we'd have been...you know what...
Was it worth it? Yes.Would I do it again? Maybe......Aw...HELL YEA :flower: :bounce:
