Bob how are you going to wire bond the tank? Are you just going from the fill to the tank, then back to the battery ground or are you going to a pad on the out side of the boat below the water line? Just wondering. I haven’t keep up on the reg’s. My 222ccp has a ground pad below the water line on the outside of the transum. The 19-6 doesn't have a gas gage. So I'm going to put one on this year. when I looked at the top of the tank. Their is no ground on it . So I'm going to put one on.
Good quick way out SB!I called the engraver about the switch panel. He said the engraving is perfect. However, the laser is not getting a good job cutting the holes...the plastic is cracking in places. He is going to order more material, and do it again. I think this time we'll let another shop cut the holes (acrylic shop here) then take it to him for the engraving. Sorry for the delay.
Good quick way out SB!I called the engraver about the switch panel. He said the engraving is perfect. However, the laser is not getting a good job cutting the holes...the plastic is cracking in places. He is going to order more material, and do it again. I think this time we'll let another shop cut the holes (acrylic shop here) then take it back to him for the engraving. Sorry for the delay.
Recent events have caused the boating industry to examine the policy regarding the bonding of plastic body fuel fills with metallic caps and retaining chains. Existing USCG & ABYC policy states that the bonding of these components is voluntary. A study by IMANNA Laboratories has shown that connecting the metallic retaining chain and cap of a plastic body fuel fill assembly to a boats bonding system may result in electrostatic discharge from a land-based fuel pump nozzle to the metallic components of the assembly when the boat is not in the water. This condition does not exist when the boat is in the water due to the equalizations of the ground potentials between the fuel pump nozzle and the boats bonding system. It is recommended by ABYC and the USCG that new and existing installations of this type of fuel fill assembly DO NOT INCLUDE any attachment to the boats bonding system. Existing connections should be removed from the point of connection to the boats bonding system to the fuel fill assembly. Removal of the metallic components of the assembly is not necessary; however, the U.S. Coast Guard and ABYC still require that METALLIC body fuel fills be bonded.
Scotty,Frank emailed me yesterday (never checked emails, was like computer awol yesterday!), said he was starting on your stuff but hadn't received the console door yet. Might want to contact him...
Another good day - keep it coming and thanks!
