Engines & engine woes
tilt and trim motor 94 johnson 112
Topic: tilt and trim motor 94 johnson 112 (Read 661 times)
February 27, 2011, 02:50:57 AM
Read 661 times
tbhobe
February 27, 2011, 02:50:57 AM »
looking for a good used or where to find a good price for a trim and tilt motor for 94 112 johnson also what would be the best way to remove old pump lift motor off boat or remove left side of transom bracket any help please
February 27, 2011, 08:07:18 AM
Re: tilt and trim motor 94 johnson 112
February 27, 2011, 08:07:18 AM »
I have to do the same thing on my 94 175. My motor guy says its easier to remove the motor for access to the bolts. While you have it off make sure and reseal the holes in the transom. Good luck!
