Author Topic: Seals for Sea Star Hydralic steering  (Read 975 times)
February 21, 2011, 11:54:47 AM
Read 975 times
Far67rar
« on: February 21, 2011, 11:54:47 AM »
My 17.5 Aquasport has Sea Star Hydralic steering, the seals in the end caps on the ram have started laeking. West Marine want $114.00 for what appears to be the cap and seals. My question is does anyone know where i can buy just the seals
February 21, 2011, 12:10:09 PM
Re: Seals for Sea Star Hydralic steering
« Reply #1 on: February 21, 2011, 12:10:09 PM »
Quote from: "Far67rar"
Here's a start. Nothing's cheap nowadays.
http://www.surplusunlimited.com/mm5/mer ... ore_Code=1
February 21, 2011, 12:21:38 PM
« Reply #2 on: February 21, 2011, 12:21:38 PM »
Far67,
The seals are what Teleflex calls "End Glands".  I've replaced quite a few in the last few years, the cheapest I've found has been $94 including the spanner wrench.  And as far as I know, you have to buy the end caps as well as the seals...
February 21, 2011, 08:20:09 PM
Mark Sr
« Reply #3 on: February 21, 2011, 08:20:09 PM »
You have to hope you just need the seals on the End Glands.I replaced mine and the steering didn't work right.There's also seals in the hydraulic cylinder itself.They are like check valves.If you go on the Teleflex site and look up the number on your cylinder it will give you an exploded view of the hydraulic pump.I had to buy a new cylinder.
Mark Sr
February 21, 2011, 09:17:18 PM
« Reply #4 on: February 21, 2011, 09:17:18 PM »
Quote from: "Mark Sr"
Mark,
If the steering works fine, but you notice some hyd fluid in the splashwell, then all you'll need is the end gland seal kit.  If there are other issues such as jerkiness, dead spots, harder to port than starboard, etc., that bleeding hasn't taken care of, there may indeed be a problem futher into the cylinder...or helm pump, for that matter...
February 22, 2011, 11:39:15 AM
Far67rar
« Reply #5 on: February 22, 2011, 11:39:15 AM »
Steering works fine, just leaks alittle out of the end caps. It leaks a very small amount about a table spoon or two a month but I keep the boat in the water and when it rains it gets washed into the bilge where the bilge pump pumps it out into the canal. NOT GOOD!
February 28, 2011, 01:14:52 PM
Far67rar
« Reply #6 on: February 28, 2011, 01:14:52 PM »
Thank you for the advise, I ended up going to my local hydralic shop they measured the end glands and were able to supply me with all the seals for 27.00
