Gallery
Gallery
Aquasport Discussion
200 ccp hull deadrise
Topic: 200 ccp hull deadrise (Read 1363 times)
January 05, 2006, 08:15:27 AM
Read 1363 times
jy118lfd
January 05, 2006, 08:15:27 AM »
Anyone know the deadrise on the 200 ccp and can anyone tell me how good they ride. I am looking at a 200ccp for 1500 and it needs a transom but looks like a good project. I have a 73 19-6 right now with the modified v 12 degree hull and was wondering how the 200 would be. I really like the splashwell and the large fishbox as well as the higher gunwales on the 200.
Does this hull use a 20 inch motor also?
January 05, 2006, 01:45:39 PM
Mechanical Master
200 CCP Specs
January 05, 2006, 01:45:39 PM »
Here are the stats I have for the 200 CCP (from AS brochure & spec sheet):
Hull: Deep V, 20 degree deadrise
Length: 20'2"
Beam: 7'10"
Draft, hull: 12"
Transom height: 25"
Weight: 1900 lbs.
Capacity: 1800 lbs.
Max HP: 200
Fuel capacity: 73 gal.
Hope this helps!
January 05, 2006, 05:11:30 PM
jy118lfd
January 05, 2006, 05:11:30 PM »
great info thanks. I am gonna try to rescue this aquasport from the scrap heap
January 10, 2006, 05:15:02 PM
jy118lfd
January 10, 2006, 05:15:02 PM »
Any owners of these out there. How do they ride? What power do you have? How wet are they? I am just looking into the handling of this boat andhow well anyone likes them
February 03, 2006, 02:01:00 AM
Anonymous
Guest
February 03, 2006, 02:01:00 AM »
I have a 1985 200ccp since new. I troll off-shore most of the time. The boat does not like quartering seas that much due the fairly big chines. It does hold its own head on into the seas as long as you are reasonable to what to expect from a 20 ft. boat. The high gunnels and flat deck make it feel secure. I put a 2003 175 Evinrude on it and now get double the gph I did with the original carbed 175 and have no intensions of selling it.It is a big 20ft. boat. but not a 25 contender but on average days I am right there with them 20 miles off Port ST. Lucie FL.
February 03, 2006, 10:20:11 AM
jy118lfd
February 03, 2006, 10:20:11 AM »
Thats what I was looking for as the 19-6 I have now feels small 20 miles out in the mud hole off nj. It works great but I just want the higher gunwales and splashwell as well as the 20 degree deadrise.
