Author Topic: Offset trim tab anodes???  (Read 2962 times)
February 21, 2011, 07:10:28 PM
TheKid
Re: Offset trim tab anodes???
« Reply #15 on: February 21, 2011, 07:10:28 PM »
Thanks, definitely not hydraulic.
I try to post pics when I can. Usually I am work when I think of these questions or its too dark.
Thanks again.
Update. I did not disconnect and test as previously stated.
I did rotate back and fourth and the steering is fine stop to stop.
That should point to the prop torque/tab setup...correct?
Next weekend on the water I'll try making adjustments.
