Author Topic: radar installation location  (Read 642 times)
February 12, 2011, 11:03:51 AM
Read 642 times
fishingdave
« on: February 12, 2011, 11:03:51 AM »
Hi i am trying to figure out where would be the best place to mount radar dome on my hardtop. I also want to install a search light and dont want it to get into the way. Should i mount the radar on a stand higher then the light? Its for my 225 explorer with hard top.
thanks
dave
2005 aquasport 225 explorer
2005 Yamaha 200F
February 12, 2011, 11:40:21 AM
DOCREED
Re: radar installation location
« Reply #1 on: February 12, 2011, 11:40:21 AM »
If you put it on a tower, it should clear the light.  Plus get a tower with a few degrees lower in front to help the radar be more level when you are running.  Most towers have a provision for a light bar to get the all around white light above the dome.  Or, i had an aluminum pipe made with a platform for the light and a base that screws on a antenna mount so i can fly a flag and fold it down for trailering and so it will fit on my covered lift.
89 250 CCP
full transom
February 12, 2011, 05:09:24 PM
« Reply #2 on: February 12, 2011, 05:09:24 PM »
Ditto on what Doc said about the mast and the tilt.  Mast's can be pricey, but you can also get a good looking, functional install with a C-shaped mount that bolts to plates flanking the electronics box, if your top frame has these.
There are a lot of threads on THT regarding this exact install, you may want to peruse some of them...
