The only thing I know about torsion axles is you dont ever want to hang one off the end of a ramp. It is not coming out without ripping the axle off. Usually with leaf springs if you unload the boat, you have a fighting chance of pulling her out without trashing the trailer.
I like my torsion axle. There is some drawbacks, like it's difficult to tell if the internal springs are going bad, but from what I've gathered, the torsion axle will last a lot longer than the leaf(s) with proper maintenance.A thought- you could buy a new torsion axle assembly, complete with new hubs, depending on the overall condition of your trailer. This is the route I went and I saved a boatload of money. Rebuilt my entire trailer for less than $500, and it's just as good as new and still better than used.Good Luck!
even though i keep the hubs/bearings greased, and check the spindle nut, i still keep blowing through wheel bearings, i think its too much weight for how often i trailer the boat around town...
Quote from: "Aswaff400"even though i keep the hubs/bearings greased, and check the spindle nut, i still keep blowing through wheel bearings, i think its too much weight for how often i trailer the boat around town...I think your on the right track. Assuming you have five lug wheels your probably running 3500 lbs axles and I'm sure your boat and trailer frame weigh way more than that. Add fuel, gear and such to that and your WAY over weight for a single axle... The tandem will give you 7K or so capacity depending on the wheel and tire size you pick. Plenty of capacity with a nice safety factor.Search around online you might be able to score a deal on a nice used one.wait looky here: http://tampa.craigslist.org/hil/boa/2203943523.html
Torsion axle all the way. not only do they last longer they allow your boat to sit lower and make it much easier to get in and out of.
