Author Topic: Seastar/Baystar HYD Fluid...  (Read 1101 times)
January 22, 2011, 07:40:13 PM
Read 1101 times
« on: January 22, 2011, 07:40:13 PM »
Well, seeing as I haven't had to bleed or re-fill a system lately, Christian's HydraSports begged me to go get some fluid.  Now, as we speak, Worst Marine is selling Seastar Fluid for $20/quart.  So I went to Brooksville Airport yesterday morn, Phillips Aviation fluid meeting MIL-PRF-5606H (Teleflex required)...$7.92/quart, dyed red for leak purposes...
Come spring, and you need to bleed or top off the system, VISIT YOUR LOCAL SMALL AIRPORT!!! :thumleft:  :thumleft:
January 22, 2011, 07:54:52 PM
Re: Seastar/Baystar HYD Fluid...
« Reply #1 on: January 22, 2011, 07:54:52 PM »
Great tip!  And as we all know, a little goes a long way. Pop the top on one, use what you need, save the rest to an empty plastic quart oil container, etc.
Spin the helm, bleed the system. Another good winter thing to mess with on a decent day.
January 22, 2011, 08:48:19 PM
« Reply #2 on: January 22, 2011, 08:48:19 PM »
The nice thing is the airport is 20 mins. tops down 41.  Worst is 40 mins. down 19. You take your pick, I'll take 41 heading towards Masryktown...
February 21, 2011, 08:35:34 PM
Mark Sr
« Reply #3 on: February 21, 2011, 08:35:34 PM »
Bob,
So your saying aviation fluid will work like teleflex and not harm the seals?
Mark Sr
February 21, 2011, 09:13:39 PM
« Reply #4 on: February 21, 2011, 09:13:39 PM »
Quote from: "Mark Sr"
Bob,
Mark, MIL-PRF-5606H fluids are recommended in the install manual as acceptable replacements for Seastar Fluid.  Won't void the warranty should there be a failure.  When I was at Wellcraft, we used the Shell fluid.  At Stamas, we used the Chevron fluid...
February 21, 2011, 10:28:08 PM
« Reply #5 on: February 21, 2011, 10:28:08 PM »
Around a year and a half ago, went by the local airport and purchased one gallon AIRPARTS (as listed on can) MIL-PRF-5606H Hydraulic Fluid "dyed red for identification and leak detection." Purchased per original Hatteras spec. (1964) for the steering system.
Probably enough to last a lifetime. And cheap.
Airparts Co., Inc.
2310 NW 55th Court
Ft. Lauderdale, Fl. 33309
954-739-3575
airpartsco.com
"Made by Conoco Phillips, Houston TX 77079"
CB hit a home-run today with a phone call for the fam...swing the bat, give a call. Times are still tough, biz is biz.
