Author Topic: VHF Antenna Suggestions?  (Read 4151 times)
January 27, 2011, 12:21:25 AM
Reply #30
Re: VHF Antenna Suggestions?
« Reply #30 on: January 27, 2011, 12:21:25 AM »
Galaxy 5225XT...
Now where have I seen this before?...
January 27, 2011, 04:49:42 AM
Reply #31
MarshMarlowe196
« Reply #31 on: January 27, 2011, 04:49:42 AM »
Quote from: "John Jones"
The 8 footer will have negligible improvement.
Using a line of sight calculator  (I'm sure it rounds off to the nearest whole mile.)
-assuming a shore radio with a 100' antenna.  (Port Richey TowBoat antenna is 1000' high)
-assuming from my photo 3' boat antenna maybe 8' off the water.
Line of sight distance = 18 miles.
-assuming an 8' antenna on the gunnel = 10' off the water
You have to put in a 12' height to get the calculator to change to 19 miles.
http://www.qsl.net/kd4sai/distance.html
This is my thinking too.
Honestly guys, I think I've been in 6' swells once in my boat, and I was well within sight of the the shore.  I almost never venture out more than 5 miles from shore in my 19-6.  Thanks to my GF's father, an offshore trip is planned and we are comfy safely cozy on a very young 26' Boston Whaler W/A Conquest with twins and a 12' VHF antenna.
I understand the safety aspect of the bigger antenna, but with the kind of fishing I do 98% of the time, it would be almost the same as having an 8' Antenna on a bass boat  :roll: .
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
January 27, 2011, 05:32:05 AM
Reply #32
« Reply #32 on: January 27, 2011, 05:32:05 AM »
You'll be well pleased with the Shakespeare squatty, in either format.
January 27, 2011, 08:25:35 AM
Reply #33
« Reply #33 on: January 27, 2011, 08:25:35 AM »
Quote from: "MarshMarlowe196"
 :thumright:
January 27, 2011, 01:20:00 PM
Reply #34
DOCREED
« Reply #34 on: January 27, 2011, 01:20:00 PM »
If you are going to go big, go all the way.  10db
http://www.digitalantenna.com/prods/vhfantenna_16.html
10dB is too much for these boats and will cause the signal to fade in and out as the boat rocks
odb gani is like a circle around the antenna
as the gain i increased, the top and bottom of the circle get squashed so you can hear and transmit further up to a point
89 250 CCP
full transom
January 27, 2011, 03:04:40 PM
Reply #35
« Reply #35 on: January 27, 2011, 03:04:40 PM »
Docreed is right 9 or 10 db is for a large ship or a land mount antenna that does not roll.  With that high of a gain the signal radiates from the antenna in almost flat a disc shape.  So when the boat rocks a few degrees your signal is now transmitting into the air and into the water not at the horizon.  A 3db radiates from the antenna in a torus or doughnut shape so when the boat rocks a portion of the signal is still transmitting toward the horizon.  This makes the 3db ideal for mounting on top of a sail boat mast or a small boat that rocks.  6db is the highest gain you would want for our boats since it is a little flatter pattern but will still radiate signal towards the horizon if the boat rolls a bit.  Keep in mind the db gain is not actually amplifying the signal... that is impossible... it just reshapes the signal pattern so in certain locations it would seem like the signal is amplified.
January 27, 2011, 04:46:33 PM
Reply #36
« Reply #36 on: January 27, 2011, 04:46:33 PM »
This was a joke...
I understand antenna radiation patterns and already gave my version of the effects of gain.
Higher gain does concentrate the radiation pattern for slightly more range but the tighter radiation pattern makes the radio fade in and out when the boat rolls.  Think of a donut laying on the ground and that's what the radiation pattern looks like from a vertically polarized antenna.  Now mash the donut flat.  Yes it spreads out in area covered but now the vertical coverage is concentrated in a flatter pattern.  Tilt it a little like the boat rolling and you overshoot or undershoot your target.  Like everything else one has to pick the least of the evils for their own purpose.  (antennas and radio communications were my first career choice many moons ago)
January 27, 2011, 06:38:24 PM
Reply #37
  • Information Online
« Reply #37 on: January 27, 2011, 06:38:24 PM »
Beamwidth - the higher the db the narrower the beamwidth
Range: http://reviews.ebay.com/VHF-Marine-Radio-Antenna-Buying-Guide_W0QQugidZ10000000000015940
Square Root of Height Above Water (in feet) times 1.42 equals Range in Miles
Example: Highest point of your boat is 6 feet above water. You attach your 3-foot antenna at that point. The antenna is now 9 feet above water. The square root of 9 (which is 3) times 1.42 equals 4.26 miles
January 27, 2011, 06:55:40 PM
Reply #38
« Reply #38 on: January 27, 2011, 06:55:40 PM »
Rick,
That was a good read... :thumleft:
January 27, 2011, 09:31:04 PM
Reply #39
« Reply #39 on: January 27, 2011, 09:31:04 PM »
This was a joke...
I got it too   :thumright:
January 27, 2011, 10:33:10 PM
Reply #40
« Reply #40 on: January 27, 2011, 10:33:10 PM »
Quote from: "RickK"
Rick, good job. Am making the assumption that the quoted line of sight transmission of 4.26 miles is based upon the receiving station's antenna height being the same, i.e. 9 feet above sea-level?
Thanks.
January 27, 2011, 10:40:45 PM
Reply #41
« Reply #41 on: January 27, 2011, 10:40:45 PM »
Kind of related to this discussion, I noticed the other day when installing my new Icom, the cable coming from my antenna, about 6" from the base of the antenna, the outer coating cracked, probably from the radius bend created from raising and lowering the antenna, you can see the shield of the coax, everything is intact, but there of course is an opening in the skin of the cable, which would allow moisture, corrosion etc... thinking of sealing with some west marine liquid electric tape, the black gooey stuff?? Opinions on reception/transmitting with a compromised jacket??
January 27, 2011, 11:09:21 PM
Reply #42
« Reply #42 on: January 27, 2011, 11:09:21 PM »
If its just the outer vinyl/rubber compromised, and not the interior metal weave, I'd say you're good. Repair as stated...you are again ready to 'splain how the biggun' got away.... :wink:
January 28, 2011, 05:40:35 AM
Reply #43
« Reply #43 on: January 28, 2011, 05:40:35 AM »
Thanks.
The article explains the basics though, which is enough for most of us - it can get very complicated as you try to design a point to point link. I am no expert but I do work in the RF industry and am learning more each day.
Beamwidth - to keep this very simplistic - on an omni antenna think of the radiated signal as a donut of radio signal around the tip (as mentioned already here) - 360 degrees around.   But to get gain think of the signal being squashed into a sort of "V" (remember I said simplistic) that the donut now radiates in.  If two antennas can "see" each others "V", or the "V"s cross, then life is good because they lie within each others beamwidth.
If you read just below the distance example in the article it explains that you have to do the calcs for the other end also.
If we do the calcs on the 1000ft antenna mentioned above:  The sq rt of 1000 is approx 31 X 1.42 = approx 45 miles.
I would hope that the high antenna was one that has a wide vertical beamwidth (like a 3db) so it would receive a signal from a much lower height antenna, even if someone had increased the power using a higher gain antenna, but ended up narrowing it's beamwidth.
If that 1000ft attenna was a high dB one the vertical beamwidth would be very narrow and it would not receive as well because most other signals would not be within it's beamwidth (like a boat right below it would not be in it's beamwidth but one out farther may). Any antenna on the same level would have good reception with it.
January 28, 2011, 10:54:16 AM
Reply #44
« Reply #44 on: January 28, 2011, 10:54:16 AM »
OK I see it now..  I should have read up few more posts.    Sarcasm doesn't always work out the way you intend it when written vs spoken.    I guess thats why we have these little guys:   :roll:
