Author Topic: Just curious  (Read 1051 times)
January 21, 2011, 09:51:18 PM
Read 1051 times
FLChris
Just curious
« on: January 21, 2011, 09:51:18 PM »
I been curious about this for awhile and i was wondering if it could it be done. I was wondering if you can flat back a 1977 17ft aquasport, because i saw a newer 17ft mako flat back with a motor mount.  So can it be done and as anyone done it or seen one?
I Am Just Curious
thank you
chris
January 22, 2011, 07:42:17 AM
akbridge
Re: Just curious
« Reply #1 on: January 22, 2011, 07:42:17 AM »
A flat back AS refers to the dead rise at the transom.  A flat back has close to zero degrees of dead rise.  A 17 AS has twelve degrees.  So the simple answer is no you can't make it a flat back.
But I think you are asking about full transoms.  In that case yes you can.  You would need a porta-bracket or of the like.  You might run into issues of too much weight off of the stern.  These boats like a light engine on the transom.
Why do you want to go to a full transom?  Are you getting waves over the stern?
January 23, 2011, 10:07:34 AM
FLChris
Re: Just curious
« Reply #2 on: January 23, 2011, 10:07:34 AM »
Quote from: "akbridge"
I was just curious because i seen some 17ft with a flat backs. so that y i was asking
January 23, 2011, 03:17:17 PM
Re: Just curious
« Reply #3 on: January 23, 2011, 03:17:17 PM »
Chris you must have seen this,does make a big difference.
January 23, 2011, 03:33:28 PM
akbridge
Re: Just curious
« Reply #4 on: January 23, 2011, 03:33:28 PM »
Hmmm after seeing the mako.  It makes sense.  It looks good.  The only thing I don't like is how far the engine is hung back there.  But I think I have seen 17 prolines come from the factory with a full transom.  I would make a very different AS when compared to all the others.  I wish I had a full transom sometimes when coming off a plane in rough water.  Lets see ya do it!
January 23, 2011, 10:08:34 PM
FLChris
Re: Just curious
« Reply #5 on: January 23, 2011, 10:08:34 PM »
I like it and add alittle more space on the boat and more options too. The big thing is i really dont feel comfortable doing that  work pair to the floor and dont know how much it would be. Here is a pic of my 17ft and my motor doesnt really sits look.
[/img]
[/img]
I would like to do something in the rear to hide the oil tank and lines this winter when i restore it.
January 23, 2011, 10:36:13 PM
Re: Just curious
« Reply #6 on: January 23, 2011, 10:36:13 PM »
Chris take off the first [img] at the the beginning and the last [img] at the end of each line and you pics will show. :thumright:
January 23, 2011, 10:41:23 PM
FLChris
Re: Just curious
« Reply #7 on: January 23, 2011, 10:41:23 PM »
Sorry
January 23, 2011, 10:58:10 PM
Re: Just curious
« Reply #8 on: January 23, 2011, 10:58:10 PM »
Don't be sorry you got it,heck i still catch myself doing that sometimes. :salut:
Nice boat by the way,that's about perfect for the Boca area,you won't get beat up when the sea breeze kicks up like all those flats boat guys.
January 24, 2011, 08:25:41 AM
FLChris
Re: Just curious
« Reply #9 on: January 24, 2011, 08:25:41 AM »
Thank you and yes i can get into some good place around boca. In the next couple week i am going to start restoring it, all i need left is resain and paint.
January 24, 2011, 08:37:44 AM
Re: Just curious
« Reply #10 on: January 24, 2011, 08:37:44 AM »
Quote from: "Circle Hooked"
Chris,
When you post, do not click on the the "IMG" button in the tool bar above. Just get your pics to PB, size and replace and then click in the IMG line there (just like you're already doing now). Then place the pic where you want in your post and hit "Ctrl V". Clicking the IMG button in the tool bar adds the additional "image code". Only use that if you somehow know the code for a pic and you want to manually type it in. Same thing for the URL button.
Now,
Disrobe her and show us the good stuff  :wink:
January 24, 2011, 09:01:59 AM
SC170nFL
Re: Just curious
« Reply #11 on: January 24, 2011, 09:01:59 AM »
Nice boat Chris. I have one on the other side of the bridge and it works great in the shallows of Charlotte Harbor. See you out there sometimes, maybe at the spring get-to-gather. Mine has a 140, which is too heavy, but I just put plugs in the scuppers.
Johnmy 222my 170
Member # 1013
January 24, 2011, 04:24:44 PM
Re: Just curious
« Reply #12 on: January 24, 2011, 04:24:44 PM »
Quote from: "FLChris"
Chris just have it done by May for the Gathering  :D
January 24, 2011, 06:14:48 PM
FLChris
Re: Just curious
« Reply #13 on: January 24, 2011, 06:14:48 PM »
I will and do u guys know how to take the Aquasport logo off the side of the boat with out damaging it?
January 24, 2011, 06:39:14 PM
Re: Just curious
« Reply #14 on: January 24, 2011, 06:39:14 PM »
Drill out the rivets? :idea:
