Ok, heres my $.02The goal is get the fuel fill hose through the notch in stringer and on to the tank inlet. First, take a regular steel snake wire and feed it from the gunnell fill to the tank. Tie a piece of 1/4"-3/8 nylon rope to the snake wire and pull it through to the tank. Disconnect the snake wire. Next make two small cuts with a sharp knife, top and bottom in the fuel fill hose behind a couple of wraps of the integrated wire reinforcement. Feed through a big cable tie (3/8-1/2" width cable tie) through the slits you made and tighten the cable tie until it makes the fill hose into an oval; reduce the diameter top and bottom by at least 1/3 of the fill hose diameter in the free state. Take some vasoline and lube that fill hose up good on the outside so she will find her way through to the promised land without resistance (we know how to do that). Tie the cord through the cable tie and begin to pull with authority while an assistant provides pushes on the hose from the outside while you pull on the cord; it may take some timed in and out motion with the assistant until she finds that notch in stringer and comes on in. Once you pull her through cut the fuel hose off past the area where you made the cable tie attachment and clamp her to the fuel neck with two hose clamps pulling clockwise and counterclockwise to oppose one anothers clamping force. If the fill hose provides some resistance while trying to do this; poor a glass of red wine down the fill hose and talk gently to her during the process and she will submitt.
