Author Topic: What's the best motor?  (Read 751 times)
December 27, 2005, 03:16:58 PM
Read 751 times
Mr. Osprey
« on: December 27, 2005, 03:16:58 PM »
What I mean by this is what is the best motor you could buy used (before 1995), used (after 1995), and new between 90hp and 115hp and 130 at a good price? With my merc running out of life, I want to have ALL of my options open when the Merc kicks the bucket. What do you guys say? Any preferene between the numbers of motors avaible?
Mr. Osprey
1971 Mako 17 Angler
1986 Evinrude 88 SPL
December 28, 2005, 05:55:51 AM
« Reply #1 on: December 28, 2005, 05:55:51 AM »
I recently repowered because 1) I had a cylinder that was getting low compression but probably would have lasted me a while longer 2) it was 18 years old and was just a matter of time.
I researched all the possibilities for my old boat with the main concern being weight of the newer models.  The newer 4strokes can weigh as much as 100+ lbs more for the same hp as a 2stroke (which are hard to find new anymore because of the clean air laws).
I finally decided on going with a rebuilt older motor because 1) it was close in weight to the existing motor 2) was about the same power as the existing.  I didn't want to step down in power.
I had a '88 rude 110 and repowered with a '98 johnson 115.  The motor came with a 1yr mechanical and electrical warrantee (which I've had to use already with no problems) and cost about half of a new motor.
My $.02
