Author Topic: Isolator Question  (Read 880 times)
January 15, 2011, 07:29:40 PM
Read 880 times
Mark Sr
Isolator Question
« on: January 15, 2011, 07:29:40 PM »
Do  any of you guys with 3 batteries use an isolator to control the charge on your batteries,if so what brand do you use and which do you think is better.I'm going to go with a 3 bank 70 amp one.
Mark Sr
Mark Sr
January 15, 2011, 11:09:04 PM
Re: Isolator Question
« Reply #1 on: January 15, 2011, 11:09:04 PM »
Quote from: "Mark Sr"
Mark Sr
Mark,
Blue Seas, BEP, Yandina, ProMariner...can't go wrong with either one.  They all work basically the same way, combine the batts when the minimum charging voltage threshold is met, isolate when the charging voltage falls below the threshold...
January 16, 2011, 02:32:13 PM
Mark Sr
« Reply #2 on: January 16, 2011, 02:32:13 PM »
Thanks Bob,I'm going to rewire my 245 TM this spring and I'm going with an isolator.I had to many battery issues this season,bad wiring being one of the reasons.
Mark Sr
January 16, 2011, 04:05:26 PM
« Reply #3 on: January 16, 2011, 04:05:26 PM »
The only ones I have messed with are the Blue Seas ACR's.  I can vouch for them.
January 17, 2011, 12:41:32 AM
« Reply #4 on: January 17, 2011, 12:41:32 AM »
My Blue Seas has worked great.
January 17, 2011, 08:34:43 AM
« Reply #5 on: January 17, 2011, 08:34:43 AM »
Another vote for the Blue Seas units.
I don't have one on my boat but have one on my current motorcycle and it works fine, especially with the weather and vibration.
January 17, 2011, 12:25:39 PM
Mark Sr
« Reply #6 on: January 17, 2011, 12:25:39 PM »
Thanks guys,
Is the Blue Seas ACR stand for auto. charging relay? The reason I ask is that all the isolators I see have fins on them and Blue Seas is a black box.Is that correct? Also I only see A & B bolts on relay for two batteries.I need one for 3 batteries.Anybody have a pic or number for one? This will be in conjunction with 2 battery selector switches.
Mark Sr
January 17, 2011, 10:11:46 PM
Radioshop
« Reply #7 on: January 17, 2011, 10:11:46 PM »
Newmar is pretty good stuff too, if you can't get Blue Seas.
Miamuh, Florida
January 17, 2011, 11:58:02 PM
« Reply #8 on: January 17, 2011, 11:58:02 PM »
Quote from: "Radioshop"
BEP VSR... :thumleft:
