Also, It appears the sealant around the edges of the top cover is plumbers putty. Not a bad idea if you ask me. Is this common? I have a tub left over from redoing my sinks in the house. That would be easy...and cheap...and easily removable again. Hmmm......
Yes it is mine was a Florida Marine fuel tank on my 81 222 CCP (85 gal)I would take Capt Bob's recommendation and replace the tank. They are a little more expensive than all my other quotes, so I went with a local guy here in Naples who is making me a custom aluminum tank to fit.I'm in the middle of my install, waiting for the tank to be finished and doing a fiberglass repair to the fuel compartment.Good luck Kevin
You are saying this was your boat or fuel tank?
Yes it is (a Factory installation). Mine was a Florida Marine fuel tank on my 81 222 CCP (85 gal)Good luck Kevin
