The fin on the front of the cavitation plate digs into the transom just above the plug. I'm thinking of getting the ol grinder out and fixing that. Any one used the wedges or got any other good idea's?Smitty
Quote from: "smitty 1"The fin on the front of the cavitation plate digs into the transom just above the plug. I'm thinking of getting the ol grinder out and fixing that. Any one used the wedges or got any other good idea's?SmittyI suggest:1-get a new mechanic. He does not know what he is doing. Yes, wedges can help some boats but you have other issues that need fixed first.2-drop the motor down until the anti-ventilation plates is even with the bottom of the keel3-trim all the way down and check hole shot. Make sure the little rod is in the bottom hole.4-get up to speed and adjust the trim for top speed at wide open throttle. If it tries to go over redline, throttle back.5-tell us the max rpm you obtained as well as prop specs or prop model number at least.
I'd like to see a picture of how the front of your antiventilation plate is able to contact the transom. Something sounds a little weird on this set up.
Smitty,Just pull the pin out of the bottom hole and move it up several holes. I'll assume that is what Gran is saying.That's all that is wrong with the motor hitting the transom. You can now see it in the second/fourth photos. That will solve the transom problem, assuming the pin's not frozen in place. PS.... I run 18 x 9 tabs on my CCP. They pop it up on a plane like an emergency blow on a submarine[/color] :o
