Author Topic: Thru-hulls  (Read 2215 times)
December 29, 2010, 10:12:16 AM
Read 2215 times
Mulv80
Thru-hulls
« on: December 29, 2010, 10:12:16 AM »
I would like to replace the plastic thru-hulls on my 99' Aquasport 215 DC.  Does anyone know the sizes and shapes so I can order them and have the parts ready when its time to replace them.
99\' Aquasport 215 DC, Johnson 200 Ocean Pro
December 29, 2010, 11:22:05 AM
Re: Thru-hulls
« Reply #1 on: December 29, 2010, 11:22:05 AM »
Here is a list of suppliers from seabob good luck in your search!
http://classicaquasport.com/smf/index.php?topic=5885.msg40124#msg40124
December 29, 2010, 01:02:45 PM
Re: Thru-hulls
« Reply #2 on: December 29, 2010, 01:02:45 PM »
Quote from: "Mulv80"
Generally, these are the sizes...
Bilge pump discharge, 1 1/8" Barb
Sink and tub drains, 3/4" Barb
Fishbox and livewell drains, 1 1/2" Barb
Cockpit Drains/Scuppers. 1 1/2" Barb
Macerator Discharge, 1" Barb
If you're going to simply replace like with like (white nylon), iboats has some good prices.  If you're thinking about the newer SS capped acetyl resin ones, well, I have quite a few I took off a Proline hull replacement a couple of years ago that are about brand new.  They look like this...
December 29, 2010, 07:33:29 PM
Mulv80
Re: Thru-hulls
« Reply #3 on: December 29, 2010, 07:33:29 PM »
Thanks again for you help Bob, you are a god send when it comes to advice and info on boats and I appreciate it.  I'm attaching a picture of an identical boat to mine, my boat is still under shrinkwrap so no pictures of mine till spring.  I circled the thru-hull I want to replace, its dry and pitted.  Looking at it from the outside of the hull it looks like it has a bend to it.
December 29, 2010, 07:53:39 PM
Re: Thru-hulls
« Reply #4 on: December 29, 2010, 07:53:39 PM »
Looks like an 1 1/2".  I have 2 that are 1 1/2" 90s, SS capped...
BTW, this is what I have...
January 03, 2011, 04:39:52 PM
Mulv80
Re: Thru-hulls
« Reply #5 on: January 03, 2011, 04:39:52 PM »
Thanks for posting the pictures.  Its going to be a little while till I can get the exact measurements off the bot.
January 08, 2011, 10:15:06 PM
Glock Diver
Re: Thru-hulls
« Reply #6 on: January 08, 2011, 10:15:06 PM »
Bob, what about the fuel overflow?  Not exactly the same type of thru-hull, but mine needs to be replaced. Must've hit it with something.
January 10, 2011, 06:53:28 PM
Re: Thru-hulls
« Reply #7 on: January 10, 2011, 06:53:28 PM »
Quote from: "Glock Diver"
Mike,
What, your Fuel vent fitting?  5/8" barb.  I do have a spare, need to clean it up though...
January 10, 2011, 08:58:43 PM
TheKid
Re: Thru-hulls
« Reply #8 on: January 10, 2011, 08:58:43 PM »
Those look purrty. How much for the lot?
January 10, 2011, 10:19:06 PM
Re: Thru-hulls
« Reply #9 on: January 10, 2011, 10:19:06 PM »
Bob, thanks for the heads up on the thru-hulls, and your input on the outlet sizes.
January 11, 2011, 02:03:00 PM
Re: Thru-hulls
« Reply #10 on: January 11, 2011, 02:03:00 PM »
OK, Lewis needs an 1 1/2" straight, Scott needs an 1 1/2" straight and a 3/4" straight, and it looks like Mulv80 needs an 1 1/2" 90.  So, The Kid, let me see what that leaves me, and I'll let you know via PM.  Cool?
And Mike, let me see if I can clean up the SS vent fitting I have...
I'm a busy boy today... :shock:  :shock:
January 11, 2011, 04:11:00 PM
Re: Thru-hulls
« Reply #11 on: January 11, 2011, 04:11:00 PM »
Bob,
Did you ever receive my PM :?:
January 11, 2011, 04:43:35 PM
Re: Thru-hulls
« Reply #12 on: January 11, 2011, 04:43:35 PM »
Quote from: "Capt. Bob"
Bob,
Bob,
Yes, I did.  Unfortunately, I only have (2) that are 1".  Now, if you are using the cheaper ribbed bilge pump hose with the smooth clamping collars every foot, you'll be able to tighten down #16 hose clamps and that hose will work with the 1" barbs.  If you are using the heavy wall smooth bore hose, you can't compress the hose down enough to where it won't leak.
Let me know what you've got.  If so, the (2) 1" barbed t/hulls are yours...
January 11, 2011, 05:19:04 PM
Re: Thru-hulls
« Reply #13 on: January 11, 2011, 05:19:04 PM »
No Bob,
I'm using the heavy walled hose. I would need the 1-1/8.
Maybe next time.
January 11, 2011, 06:08:25 PM
Re: Thru-hulls
« Reply #14 on: January 11, 2011, 06:08:25 PM »
No Bob,
Maybe next time.
CB,
Just bought Stalon 1 1/8" t/hulls for the Doc's Talon at a pretty damn good price.  Let me see if I can find...
