Author Topic: Performance Data/Numbers  (Read 10121 times)
October 11, 2010, 08:00:08 PM
Reply #30
Re: post your boat motor and prop pitch!
« Reply #30 on: October 11, 2010, 08:00:08 PM »
Quote from: "fishingdave"
ALL TERMS IN mph PER GPS , circle is that per gps? its seems kind of high, what are the rpms you runing at?
Yes MPH per my Garmins,i use two,i get 55-5700 RPM out of her,one reason may be i don't have a hard top,and when the Bimini tops are tucked in the boots not a lot of drag,i would also be curious on the motor mounting heights on the boats.
October 11, 2010, 08:29:32 PM
Reply #31
« Reply #31 on: October 11, 2010, 08:29:32 PM »
1996 200 Osprey
1990 200 hp Evinrude
13.5 x 23p OMC Renegade 4-blade
so far get between 50 and 53 mph @ 5000 rpm on raymarine GPS
just me, 1/2 fuel,, full livewell, trimmed out on a 6 to 8 inch chop...
but cruises 40 mph at 4000 rpm 8)
need to come down 2 inches to get the magical 5500 rpm
running upper 40's in tampa bay trimmed level:
http://www.youtube.com/watch?v=rpHe2Qyz8JQ
low 50's
http://www.youtube.com/watch?v=j9TseYzLk3s&NR=1
October 12, 2010, 04:48:47 PM
Reply #32
Mike453
  • NorthEast
« Reply #32 on: October 12, 2010, 04:48:47 PM »
I'm running 115 Johnson with 14 1/2 x19 prop yesterday in 1.5' seas 35 mph with full tank 3 persons aboard.
2000 aquasport 200 osprey with 115 johnson
October 13, 2010, 02:16:27 PM
Reply #33
Ben87
« Reply #33 on: October 13, 2010, 02:16:27 PM »
1987 Osprey 222.
2006 Mercury OptiMax 150-HP
Had a 15x17P 3 blade AL
Now have a 15x16 4 blade AL.
October 13, 2010, 03:33:44 PM
Reply #34
billsaquasport
« Reply #34 on: October 13, 2010, 03:33:44 PM »
250 CCP Honda 225 17p. Dont run it wide open very often but I know I have seen 41mph at 5500. I will confirm speed and RPM this weekend. Cruise at 3800/4000, 25/28mph at 6/7gph on flow meter. Average around 3.75mpg with this prop on a normal day Dolphin fishing.
October 13, 2010, 09:13:37 PM
Reply #35
akbridge
« Reply #35 on: October 13, 2010, 09:13:37 PM »
1971 AS 170
1992 Evinrude 90 two smoke, on a jack plate, low water pickup
Powertech 13.25x17 RED3
Tachs out at 5200 RPM WFO at 40 mph, will plane out at 17 mph,
Needs more stern lift: either trim tabs, transom wedges, or a stern lifting four blade prop.
October 15, 2010, 01:07:57 PM
Reply #36
illman
« Reply #36 on: October 15, 2010, 01:07:57 PM »
1995 175,yamaha 90 hp,17 pitch,5200 rpm and 38 mph.,put on the trim tabs akbridge you'll love them.
October 15, 2010, 01:59:28 PM
Reply #37
« Reply #37 on: October 15, 2010, 01:59:28 PM »
73 22-2, twin 1995 115 mercs, 4 blade SS turbo`s 13 1/4 X 18P, tower, 60 gals gas, 4-6 mixed weight people, usually atleast one person in the tower, factory stern livewells, 41 mph @5200 rpm, 23 gph, summer. Cruise @3400 27mph 10 gph. This is my usual load.
October 15, 2010, 06:42:58 PM
Reply #38
« Reply #38 on: October 15, 2010, 06:42:58 PM »
AS's are no speed demons but seems like by what everyone has posted so far, i have the fastest AS on a regular basis... gets up to 45-47 mph in a heart beat but takes about another 1/2 mile to get from 45 to 53
a 200 osprey at 53 mph is quite a fun ride 8) , now if only i could hang a 250XS merc optimax on my transom :shock:  :twisted:  :cheers:
October 15, 2010, 07:57:07 PM
Reply #39
MarshMarlowe196
« Reply #39 on: October 15, 2010, 07:57:07 PM »
Quote from: "Aswaff400"
I could mount a chevy 350 on a Go-Cart and achieve similar results  :?   I'm just giving you a hard time, that kind of performance does sound fun.  :twisted:   I just don't know if I could ever walk away from 6mpg.
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
October 15, 2010, 08:12:45 PM
Reply #40
« Reply #40 on: October 15, 2010, 08:12:45 PM »
Briefly owned a 1996 Allison XT 21 drag, 2.5L EFI 280 hp merc @ 7500 rpm 28" pitch Triton propeller 1:78 torque master gearcase, 94 mph in 1/8 mile. Congradulations!
October 16, 2010, 08:44:44 AM
Reply #41
« Reply #41 on: October 16, 2010, 08:44:44 AM »
Got the Mercury Enertia 15 X 15 yesterday from Ken at Prop Gods for a trial run today.  Boy that is one different looking prop from what I have seen with all these other ones.  The blades are larger, seem to be a little thicker or heavier near the tips of the blades, and the ventilation hole I can stick my finger through.  So this afternoon I have three final runs to do, #1 the original Yamaha re-pitched prop (15.25 X 15.5), #2 New out of the box PowerTech 15 X 15, and #3 the Mercury Enertia 15 X 15.  I am going to make a quick spreadsheet with RPM, Speed, GPH and any notes on general performance.  So I should be able to see afterwards which one is the best value, I know Ken said the Enertia was $500... I think the powertech is around $300.  More later
October 16, 2010, 09:04:52 PM
Reply #42
« Reply #42 on: October 16, 2010, 09:04:52 PM »
Well I guess there are worse ways to spend the afternoon than cruising around testing props??  The Mercury Enertia
15 X 15 took it hands down, just looking at it next to the 15 X 15 powertech, it dwarfs the PT.  The blades are larger and a different design, and it really gets some bite, just what I needed for this big heavy Osprey.  Here are the detailed numbers, the WOT is about the same, but the cruise speed-to-RPM is where the Enertia excells, and the dig coming out of the hole is night and day.
                POWERTECH 15 X 15                       MERCURY ENERTIA 15 X 15
RPM
2500          9.2 MPH @ 5.5 GPH                        10.5 MPH @ 5.8 GPH
3500          15.5 MPH @ 8.4                             22.5 MPH @ 10.2
4500          29.5 MPH @ 11.6                           32.1 MPH @ 12.9
WOT          5600 RPM, 38.3 MPH, 20 GPH           5500 RPM, 39.2 MPH, 19.5 GPH
Also, the enertia can be trimmed up more without a tendancy to ventilate, holds better in cornering.  I think the bottom line is, the Enertia pitch for pitch is a superior prop, but you will pay for it.
October 23, 2010, 07:43:40 PM
Reply #43
thill
« Reply #43 on: October 23, 2010, 07:43:40 PM »
1970 170 AS - 1989 Force 85, 17 pitch 3-blade Force prop - 38 mph @5,000 rpm
-TH
November 29, 2010, 09:51:12 AM
Reply #44
jdupree
Performance Data
« Reply #44 on: November 29, 2010, 09:51:12 AM »
Thanks to Marc for giving me a test run with the prop.  Took the boat out Thanksgiving day (which was beautiful).  Here is the comparison with my prop.
The prop that I have been running is a 13.75 X 17 pitch.  Here is what it did:
4000 rpm's = 25mph
WOT was 5500rpm's = 38mph
The prop that I will be getting from Marc(14.5 X 18 pitch)  Here is what it did:
4000 rpm's = 30mph
WOT was 5200 rpm's = 40.3mph
It was windy the day I did the test.  As for the top end, not much difference but could have got a little more if I would have trimmed her out more.  Hole shot was a great improvement.  Appears that at cruising speed I picked up 5mph.  Lost a little rpm's at WOT but the other positives outweighed 300 rpm's.  Feel like it is a good fit for my Mercury.
John L. Dupree, III
AQABLA84E999
Member #257
