Author Topic: Performance Data/Numbers  (Read 10120 times)
February 02, 2010, 08:27:11 PM
thennutts
Re: Performance Number
« Reply #15 on: February 02, 2010, 08:27:11 PM »
Circle Hooked,
6 Batteries= 3 dedicated for 36v trolling motor system, 1 dedicated starting and 2 dedicated for electronics
flkeyaqua,
Your 196 scoots along pretty well! Hows she handle? My cousin has an older 20 proline(70's i think) and when hes crusing and turns the wheel hard he spins out like a jet ski. Does this model boat do the same thing?
February 02, 2010, 08:37:58 PM
flkeysaqua
« Reply #16 on: February 02, 2010, 08:37:58 PM »
Its super easy to turn at low speeds upto I'd say high 20's low 30's but anything above that it takes some muscles to move the wheel. It does want to track to the port side I need to move that tab on the lower unit another degree or two.
73 19-6 w/140 Evinrude
February 02, 2010, 11:03:12 PM
thennutts
« Reply #17 on: February 02, 2010, 11:03:12 PM »
flkeyaqua,
Well thats nice to hear I didn't buy an extra large jet ski!
-Chris
February 02, 2010, 11:53:34 PM
« Reply #18 on: February 02, 2010, 11:53:34 PM »
Quote from: "thennutts"
Circle Hooked,
Sounds good,the 2nd for electronics is what i didn't think about. :thumright:
February 03, 2010, 08:24:45 PM
« Reply #19 on: February 03, 2010, 08:24:45 PM »
we're running 5 batteries on out SR, 3 house and 2 start. never had a dead battery
October 10, 2010, 11:07:42 PM
fishingdave
Performance Data
« Reply #20 on: October 10, 2010, 11:07:42 PM »
2005 explorer 225 with hard top
stainless steel prop 17"   top speed 36 @ 5500 with no trim on a 2005 yamaha F200
2005 aquasport 225 explorer
2005 Yamaha 200F
October 10, 2010, 11:37:05 PM
Re: post your boat motor and prop pitch!
« Reply #21 on: October 10, 2010, 11:37:05 PM »
97 225 Explorer,97 200 Evinrude 15x17 stainless prop top speed 40-45 depending on conditions and load.
October 11, 2010, 08:18:13 AM
« Reply #22 on: October 11, 2010, 08:18:13 AM »
Hopefully I'll let you all know by the end of the day  :roll: That is my plan for today, going down to the local shop and grab a dozen props or so, and see which one works the best...
October 11, 2010, 10:14:01 AM
jcaesar625
  • FL - North Area
« Reply #23 on: October 11, 2010, 10:14:01 AM »
are you guys talking in mph or knots? There is no way I would get 40-45 knots out of my 225 Explorer with a 225 Johnson. And even in mph, I can't get above 40 mph.
October 11, 2010, 12:00:28 PM
MarshMarlowe196
« Reply #24 on: October 11, 2010, 12:00:28 PM »
2008 Suzuki DF140
Gear Ratio- 2.38:1
Prop Pitch- 21"
Top Speed- 43MPH @ 5900RPM
(Boat has Bottom Paint)
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
October 11, 2010, 02:08:32 PM
fishingdave
« Reply #25 on: October 11, 2010, 02:08:32 PM »
ALL TERMS IN mph PER GPS , circle is that per gps? its seems kind of high, what are the rpms you runing at?
2005 Yamaha 200F
October 11, 2010, 03:19:26 PM
resyak
« Reply #26 on: October 11, 2010, 03:19:26 PM »
Hi
My 250 Xf has a pitch of 21,5 diameter 19", it gets 43 mph @ 5300 rpm with 1 person and 1/2 tank ( GPS ).
The motor is a Suzuki Df 225.
Regards
Stephen
October 11, 2010, 03:35:02 PM
« Reply #27 on: October 11, 2010, 03:35:02 PM »
200 XF  200 Merc 2.5L  14.5 x 17 Aluminum 42 MPH WOT @ 5600 RPM  Boat has bottom paint and I'm still dialing in things so I'm sure a stainless prop will help a bit.
October 11, 2010, 04:46:04 PM
« Reply #28 on: October 11, 2010, 04:46:04 PM »
1997 245 Osprey CC, 2003 250 Yamaha HPDI
Anybody need a prop changed in 10 seconds, I can do it now... wanted to do a quick post, after 9 props, the winner is: Powertech, 15 X 15, 5600 RPM, 39 MPH WOT, good all around response and GPH burn.  Ken from Prop gods is sending me a 15 X 15 Inertia to try.. syas it might be faster?? we'll see if its $200 faster... 500 verses 300??
October 11, 2010, 07:33:04 PM
maddiemutt
« Reply #29 on: October 11, 2010, 07:33:04 PM »
2000 Aquasport 250 Explorer.  Twin Evinrude 150's.  14 1/2 x 19 stainless props.  49 mph on the GPS @ WOT.
P.J.
2000 250 Explorer w/ Twin 150\'s
