Looking good! Which material did you use? Will the adhesion be okay between the old pour and the new? I have heard of guys that had to add more and drilled several vertical holes into the old pour so they would be structurally held together. They wallowed out the bottom of the holes so it looked like a cone with the small end at the top. This locked the two pours together. Just my .02!
Hi All,I guess the first question I have is how close to the edge should I cut the floor?Second would be does the 222 Osprey have an outer stringer?
