Looks great!!! What year is your CCP?
Mine is a 89. No it is a factory job...
Both of your rides look great!A little teak tip....have read that most teak oil is partially derived from vegetable oil...therefore, the black that you see down the road is actually due to mildew from the deteriorating veg. matter.Just hit it with a mild chlorine solution every six weeks...makes it much easier to re-apply the oil as needed too.
1) I have added a second display overhead so i can watch chart/sonar/radar with out splitting screens.--DONE2) Working on minor electrical problems..DONE3) Time to recoat the teak once it gets above 50!!! Oddly enough, I'm still waiting on the weather for this one.DONE4) Adding a stainless steel bow plate to break ice. (just kidding)5) Adding a second VHF with built in fog signals.6) New water pumps, plugs, filters and thermostats.7) Add LED courtesy lights in cockpit..DONE Repair rotted backrest on leaning post--DONE9) Replace cockpit floodlight (halogen) with a Taco LED floodlight... DONE10) Replace existing running lights with LED.11) Replace house battery bank...DONE12) Remove Stainless windshield rail...DONE12) Cut down plexi windshield 4" So I can see over it at night...DONE13) Check again to see if I'm listed on any trust funds so i can buy some gas:) nope ,no trust funds
The Taco spreader light was reasonably priced. About $60.00. There are much brighter but more expensive units available.The wiring in the t-top is all new in 2007 so i just replaced the fixture. The new one uses ALOT less current than the old Halogen. the Voltmeter doesnt even indicate a voltage drop when i turn it on.Dont even get me started on the running lights. It's a crap shoot everytime i turn them on. I am going to replace them with LED's... soon.A lot of the changes i made this winter are not really visable. So it wont look too much different.
Quote from: "DOCREED"The Taco spreader light was reasonably priced. About $60.00. There are much brighter but more expensive units available.The wiring in the t-top is all new in 2007 so i just replaced the fixture. The new one uses ALOT less current than the old Halogen. the Voltmeter doesnt even indicate a voltage drop when i turn it on.Dont even get me started on the running lights. It's a crap shoot everytime i turn them on. I am going to replace them with LED's... soon.A lot of the changes i made this winter are not really visable. So it wont look too much different.I was hunting for LED red/green Nav lights, but struck out. Ended up ordering them from Jamestown Distributors, for $28 each. All in all, not as bad as some of the initial LED prices I had seen.
