Author Topic: fishbox drain project  (Read 6262 times)
December 02, 2010, 06:08:37 PM
Read 6262 times
« on: December 02, 2010, 06:08:37 PM »
Started my fishbox drain project today,picked up an 8" pie plate cut the opening and drilled the hole on the bottom for the pump.Putting in the pie plate alone is a good idea as it gives good access to the bilge pump.Using the existing pump and screen as is there is still going to be about a 1/2" of water left in the box,way better than before,but not good enough.I was thinking about installing a drain like this one   http://www.marineeast.com/a_sch/sch_det ... &pid=02_07
and using some fittings and hose to hook to the pump.Any ideas would be welcome.Thanks!
Pete :salut:
December 02, 2010, 07:27:45 PM
Re: fishbox drain project
« Reply #1 on: December 02, 2010, 07:27:45 PM »
Quote from: "pete"
Started my fishbox drain project today,picked up an 8" pie plate cut the opening and drilled the hole on the bottom for the pump.Putting in the pie plate alone is a good idea as it gives good acsess to the bilge pump.Using the existing pump and screen as is there is still going to be about a 1/2" of water left in the box,way better than before,but not good enough.I was thinking about installing a drain like this one   http://www.marineeast.com/a_sch/sch_det ... &pid=02_07
Qualified Engine dept member,
Pete :salut:
Pete
Would like some pics, I especially am interested in the pie plate access to the bilge pump, since I can barley touch it even with my long arms through the rear access.  As far as the fish box, I use the original set up, but drilled a 1" or so hole in the bottom and just put a through hull fitting in there and use a rubber garboard drain plug, out when it's just sitting on the trailer with the hull drain plug out, so the rain drains out.  In when I'm using the fishbox, which actually isn't very often, with the one piece lid, removing it while everyone is in the stern fishing is a real Beech.  But if I do, I let the original pump get most of the stuff out, remove any chunks, then just rinse out with some bleach water into the bilge and let it run out.  The drain in the box is primarily to avoid the overfill during heavy rains.
December 02, 2010, 08:09:43 PM
« Reply #2 on: December 02, 2010, 08:09:43 PM »
Pete i second the need for pics,my curiosity i running wild on this one.
Marc that's not a bad idea with the drain plug,when my pump went out i removed it and left the hole open for awhile,it was nice not having water in there after a rain,but i replaced the pump now same problem again.
December 02, 2010, 08:25:37 PM
« Reply #3 on: December 02, 2010, 08:25:37 PM »
will get some pics up soon,my plan is to put a drain plug in the original hole to drain out the rainwater,also going to put weather striping all the way around the opening to stop most of the rain water from coming in.
December 02, 2010, 10:49:39 PM
« Reply #4 on: December 02, 2010, 10:49:39 PM »
You guys should have been working for AS when I was there...we would have had enough voices!!! :salut:  :salut:
December 05, 2010, 05:45:28 PM
« Reply #5 on: December 05, 2010, 05:45:28 PM »
Got all my parts and started to work some more on the fishbox,pretty happy with the results,did a test before I hard mounted everything,it left about a 1/4" inch of water in the box versus the 2 " before the mod here are some pics...
the pump
access to bilge pump
December 05, 2010, 05:49:29 PM
« Reply #6 on: December 05, 2010, 05:49:29 PM »
still need to clean up the wiring and put the weatherstriping around the edge.
pic under the box
will be much easier to work in the bilge area,can also get to the livewell plumbing from there as well :salut:
also thinking about adding a support bracket by glassing a block to the hull.
December 05, 2010, 08:42:09 PM
« Reply #7 on: December 05, 2010, 08:42:09 PM »
Quote from: "pete"
acsess to bilge pump
Pete, are these shots looking through the pie plate you put in?? The bilge pump and through hull for the washdown/livewell are that easy to access?? I'm there.... :cheers:
December 05, 2010, 08:46:25 PM
« Reply #8 on: December 05, 2010, 08:46:25 PM »
yep thats looking through the pie plate :salut:
December 05, 2010, 09:00:48 PM
« Reply #9 on: December 05, 2010, 09:00:48 PM »
looking up at the bottom of livewell
looking through pie plate
 :salut:
December 06, 2010, 03:10:26 PM
« Reply #10 on: December 06, 2010, 03:10:26 PM »
Man that pie plate would have been nice when i redid my pumps,good job Pete. :thumright:
December 07, 2010, 07:25:28 AM
« Reply #11 on: December 07, 2010, 07:25:28 AM »
A pie plate WILL get installed in Marc-Time this winter... that makes getting in the stern bilge area too easy.
December 07, 2010, 02:16:02 PM
labboss2003
« Reply #12 on: December 07, 2010, 02:16:02 PM »
I see a pie in my future :salut:
Great idea....
December 07, 2010, 06:13:18 PM
« Reply #13 on: December 07, 2010, 06:13:18 PM »
can't take all the credit,seabob was my inspiration on this one,he gave me some great ideas :salut:
December 07, 2010, 06:50:44 PM
« Reply #14 on: December 07, 2010, 06:50:44 PM »
Quote from: "pete"
Well thank both of you then because one will be in my boat soon. :salut:
