Author Topic: about water in storage compartment  (Read 791 times)
November 24, 2010, 01:31:35 PM
Read 791 times
motorman007
« on: November 24, 2010, 01:31:35 PM »
Help I need some one to tell what is wrong on my boat I have water in the storage compartment in the middle of the boat, is there a pump for this I had the boat 20 days, is it caused by one of the items on the outside of the boat the boat is a 2003 aquasport osprey 215 dc. the compartment is brtween the consoles.
November 24, 2010, 02:27:56 PM
Re: about water in storage compartment
« Reply #1 on: November 24, 2010, 02:27:56 PM »
check where the water is draining from.may just need to put a drain plug in the compartment.also was there any water in the bilge?if you have to put some water in it and see where it comes out :salut:
November 24, 2010, 04:01:06 PM
wpt03osprey
« Reply #2 on: November 24, 2010, 04:01:06 PM »
compartment in front of console ?
That should drain out through the bilge , if on level or slightly bow heavy it may not drain.
Just a Hacker
2003  Aquasport 250 Osprey
November 24, 2010, 04:42:21 PM
motorman007
« Reply #3 on: November 24, 2010, 04:42:21 PM »
Hello, it still has water in the ski compartment it is the compartment on the floor between the duel consoles it will not drain it is half full, just cannot figure it out
November 24, 2010, 05:11:05 PM
« Reply #4 on: November 24, 2010, 05:11:05 PM »
take a garden hose and try flushing out the drain,it could be clogged with debris,dead frogs,is there any thru hulls near by dripping?can you see under the deck where the drain is?there is usally a acsess port near every hose connection to allow for service/inspection,pics of deck area and drain please,is there a switch for a fish box pumpout? :salut:
