Not sure there is a freshwater vs a saltwater version. I know there is a marine vs RV version. I replaced my Rule750 that was used to supply the baitwell water and had a "T" in it for a shower (drizzle I'm sure was more like it) with a 5.0 G/min Johnson pump and that baby is sweet. I put in a 3.2 g/min pump in for the freshwater tank.Now the million dollar question - how was the pump wired so that it fed the livewell on your boat - with a float switch or just an on/off at the helm? Did it have a shutoff valve so you could use it as a shower also? I don't know how powerful a pump needs to be for the baitwell - I'm assume 500-750g/hr is sufficient and that is "volume" of water - not pressured. Your 3.3 is for pressure more than volume.
There is a point that too much water pressure in a baitwell is not a good thing - think it has to do with tank size. Anyone know?
