Author Topic: Maiden Voyage  (Read 1004 times)
November 20, 2010, 11:26:22 AM
Read 1004 times
motorman007
Maiden Voyage
« on: November 20, 2010, 11:26:22 AM »
Hello, what do I need on my boat for my first Maiden Voyage on Sunday, I plan to fish alittle bit, so far I have 6 life jackets,radio,anchor,fenders,fire extinguisher,throw cushion,rope,horn,gps/fishfinder,first aide kit,2 paddles,also camera so I can show you all the boat.
November 20, 2010, 11:40:23 AM
Re: Maiden Voyage
« Reply #1 on: November 20, 2010, 11:40:23 AM »
November 20, 2010, 12:14:21 PM
Re: Maiden Voyage
« Reply #2 on: November 20, 2010, 12:14:21 PM »
Quote from: "motorman007"
A tool kit with the basics, as well as some electrical terminals, some electrical tape, some wire (doesn't matter what color), in other words, what you need to perform the minor repairs should a problem arise.  And by all means, regardless of your destination and proximity to land, file a float plan with someone you know and trust.  Estimated time of departure, intended destination, estimated time of arrival back at the ramp or in port.  You never know, but should something go wrong, that info gives the LEOs a big head start in locating you and your passengers...
Now that all the doom and gloom is out of the way, HAVE FUN!!!  And definitely pics!!
November 20, 2010, 01:22:34 PM
motorman007
Re: Maiden Voyage
« Reply #3 on: November 20, 2010, 01:22:34 PM »
I forgot I also have towing and service on the water, looks like it is going to be 80 degrees on Sunday
November 20, 2010, 10:45:02 PM
Re: Maiden Voyage
« Reply #4 on: November 20, 2010, 10:45:02 PM »
make sure you batteries are in good shape and fully charged,if you have a load tester use it to see if they will hold a charge
http://www.harborfreight.com/automotive ... 90636.html
Have fun,Pete :salut:
November 20, 2010, 10:53:29 PM
Re: Maiden Voyage
« Reply #5 on: November 20, 2010, 10:53:29 PM »
Be sure to crank your motor at the house on the muffs before you go to the ramp, makes it a lot easier when you get there. Like they already said, HAVE A GOOD TIME!
November 20, 2010, 11:13:11 PM
Re: Maiden Voyage
« Reply #6 on: November 20, 2010, 11:13:11 PM »
Isn't it "interesting" how we all tend to focus on the negative...yet the focus is so important given the magnitude of the power of Mother Nature...
Just a thought...
November 20, 2010, 11:27:13 PM
Glock Diver
Re: Maiden Voyage
« Reply #7 on: November 20, 2010, 11:27:13 PM »
Quote from: "slvrlng"
Amen to that.  Very good advice, and I try to do it every time I go out.  These older 2-cycles can be sometimes be tempremental, and there's nothing like holding up 10 other boaters ready to launch while you're cranking your motor!  :pale:
Sounds like you're well prepared with the safety equipment.  I recently put together a "ditch bag", with some backup stuff, like a handheld VHF, flares, whistle, signal mirror, water, waterproof flashlight, power bars, sunscreen, etc...  Just a little extra peace of mind, should the unthinkable happen.
November 21, 2010, 10:46:42 AM
damnitbadger
Re: Maiden Voyage
« Reply #8 on: November 21, 2010, 10:46:42 AM »
I always crank the boat at the house so there are no surprises at the ramp. Post some pictures of those maidens now!
88\' CCP 222 w/200 EFI Merc
