Author Topic: Oil/fuel alarm  (Read 846 times)
October 01, 2010, 05:24:27 AM
Read 846 times
Mike453
  • NorthEast
Oil/fuel alarm
« on: October 01, 2010, 05:24:27 AM »
Hi.could use a little help on this one! I have a 2000 Johnson 115vxsss. I can run all day with no problem, until I need to troll or idle, Then it happens, I get a NO OIL light with a single long beeeeep. Oil tank full , Engine running (consuming oil) generally running great. I have checked all common tests for lack of oil, loose lines obstructions in both oil and fuel systems.I premixed my gas just in case, don't want any  :oops: .When this started it could be as soon as Self test cleared, or coming in to the ramp. This past weekend ran 2.5 hrs stopped several places trying   to set anchor, trolled for 25 min,Alarm sounded and promptly went off, Any ideas would be appreciated Thanks   :? .This one has me stumped, and it sucks at the ramp when you have to idle waiting to load  :oops:
2000 aquasport 200 osprey with 115 johnson
October 01, 2010, 07:54:42 AM
Re: Oil/fuel alarm
« Reply #1 on: October 01, 2010, 07:54:42 AM »
Mike,
More will comment here soon, but I think a single continuous tone is an overheating alarm?? and if it is doing it when you come back down from cruise to troll, it may be thermostats, or poppet valve?? If you have a VRO system, you should read this article attached, I found it very informative, and it dispells many rumors of the VRO system.
http://continuouswave.com/whaler/reference/VRO.html
October 01, 2010, 06:22:56 PM
Re: Oil/fuel alarm
« Reply #2 on: October 01, 2010, 06:22:56 PM »
I'll guess a dirty oil filter.
Huh  :scratch:
If it's like mine, there is an oil filter in the tank on the end of the pick up tube. Only happened once but replacing the filter fixed it.
Just a guess.
October 04, 2010, 06:56:01 PM
Mike453
  • NorthEast
Re: Oil/fuel alarm
« Reply #3 on: October 04, 2010, 06:56:01 PM »
I've checked all systems? But I think I'm Getting close, the way it acted yesterday,It seems like a possible short.
