Author Topic: broken fish box doors  (Read 777 times)
September 30, 2010, 06:51:47 AM
Read 777 times
pdionne
« on: September 30, 2010, 06:51:47 AM »
Fish box doors are cracking on my 2003 215. What to do? I was thinking of 1/4 aluminum diamond plate bolted on the inside.Any ideas? thankyou.
September 30, 2010, 08:47:12 AM
Re: broken fish box doors
« Reply #1 on: September 30, 2010, 08:47:12 AM »
While that would certainly work, you may want to consider Prisma Beams, which will stiffen up the hatches very nicely, with no bolt heads on the top side of the hatches...
September 30, 2010, 09:33:34 AM
MarshMarlowe196
« Reply #2 on: September 30, 2010, 09:33:34 AM »
You also may want to try putting a layer of Mat glass on the inside of the doors.  I did that to the lids on my stern-mount wells because they were flimsy- I can stand on them now. Are the cracks visible from the outside?
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
September 30, 2010, 08:05:20 PM
« Reply #3 on: September 30, 2010, 08:05:20 PM »
Welcome aboard pdionne  :!:  :!:
September 30, 2010, 09:12:56 PM
« Reply #4 on: September 30, 2010, 09:12:56 PM »
I helped a friend redo his hatches, tank covers, etc. on a 24 Grady several years ago.  We just cut 1/2" plywood the size of the hatch but small enough to not interfere with the hatches closing.  Glued the plywood to the underside of the covers with thickened resin, then just painted the plywood with several coats of resin for waterproofing.  Holding good so far.
September 30, 2010, 10:14:44 PM
« Reply #5 on: September 30, 2010, 10:14:44 PM »
JJ,
Way to easy... :shock:  :shock:  :shock:  :thumleft:
