Plumbing
Washdown, Livewell valve
Topic: Washdown, Livewell valve (Read 1066 times)
September 22, 2010, 10:01:23 AM
Read 1066 times
WaveDancer
September 22, 2010, 10:01:23 AM »
I am sure someone here knows where to find these so I am going to ask.
Who makes, sells the rotating valve that switches the wash-down to the live-well.
I have a 2004 Explorer that has a plastic valve that is starting to leak and I want to fix it before it gets really bad.
Does any company make a repair kit for it maybe?
Thanks in advance for your responses.
WD.
Join CCA Northwest
http://www.ccapnw.org
. If sport fisherman unite, and act as one, we can achieve anything we want, our numbers are to great to ignore.
September 22, 2010, 10:10:02 AM
Re: Washdown, Livewell valve
September 22, 2010, 10:10:02 AM »
WD,
That valve comes apart pretty easy, mine was all frozen up when I bought the bought, during the "yard period" I completely dis-assembled, cleaned and lubricated it, basically it is just a spool valve with some o-rings, you may have some dirt or salt debris lodged in there, o-rings can probably be found at a local rubber and hose place, mine just need some TLC.
September 22, 2010, 01:46:29 PM
Mark Sr
September 22, 2010, 01:46:29 PM »
A company named Bosworth makes the valves.I had to replace mine.
Mark Sr
September 22, 2010, 07:50:26 PM
September 22, 2010, 07:50:26 PM »
I tried to loosen my plastic one and it broke right off.
I replaced it at boaters world. Mine was a on/off though.
September 22, 2010, 09:32:07 PM
Rigging Master
September 22, 2010, 09:32:07 PM »
Boy, we have had a myriad of discussions on this little fellow...
...sorry, and his brothers...
Treat it like a shut-off valve in the bilge. Exercise the handle regularly, and give it a once weekly (maybe bi-weekly) shot of PB, or at least silicone spray under the white cap that covers the handle screw...
September 25, 2010, 01:14:56 PM
WaveDancer
September 25, 2010, 01:14:56 PM »
Thanks for your responses everyone!
I will try and track down the company that makes them and will also see about taking it apart to do a re-seal, just gotta wait for the albacore to leave our coastal fishing areas and it looks like that won't be happening for at least another few weeks.
WD.
Join CCA Northwest
Plumbing
