Guys
I replaced the drain hoses on the cock pit drains , in both cases the hoses were dry rotted and the hose clamps had rotted and fallen off. The bilge pump hose was trash and needed to be replaced , I am going to locate and install two drain connections on the outside hull as advised.
I test ran the engine on a portable fuel tank and it ran great , I will be inspecting , cleaning and replacing the fuel hoses into and out of the installed fuel tank.
I have had a lot of electrical gremlins as of late and found the wiring to be a mess for the lights . I removed all light wiring and am installing new . These will be red for positive and black for ground , as I have found many colors on the same wire. There must have been several patch jobs and quick fixes during the old girls life. I have installed new fuse holders in the control panel and labeled each wire for future reference.
I also found that the small black with yellow stripe wasps love the transom area !
