Author Topic: Deck fuel filler  (Read 654 times)
September 03, 2010, 01:46:45 PM
Read 654 times
Robob
Deck fuel filler
« on: September 03, 2010, 01:46:45 PM »
I have a 1995 175 Osprey with a deck fuel illl on th starboard gunwale.
The black plastic cap (Perko) is cross threaded and seems to be hard to find so I wanted to replace the whole unit. I removed the 3 screws holding the fill pipe flange to the deck but it won't come off. Is there something else holding it in that I don't know about?
I know someone on this forum used to build Aquasports and has a wealth of information on them.
Thanks for any help in advance,
Bob on Tampa Bay
September 03, 2010, 02:08:27 PM
Re: Deck fuel filler
« Reply #1 on: September 03, 2010, 02:08:27 PM »
You have to get inside to release the hose clamp from the neck of the filler.  If you don't have an access plate, you will need to install one.  I would go 6"
September 03, 2010, 02:49:02 PM
« Reply #2 on: September 03, 2010, 02:49:02 PM »
Robob,
As Marc stated, although I assume you already did that.  Does the fill budge at all?  On boats with aluminum tanks, one of the fill mounting screws was a t/bolt, for the bonding wire.  But because your 175 has a plastic tank, and since you said you removed all three screws, I would guess the fill has 5200 underneath the flange...
September 04, 2010, 10:03:51 AM
Robob
« Reply #3 on: September 04, 2010, 10:03:51 AM »
Duh....I finally figured it out for myself:-)
There is a hose clamp on the fill tube just below the gunwale. I wasn't looking hard enough.
Thanks,
Bob on Tampa Bay
