Author Topic: 1970 fb problems  (Read 896 times)
August 30, 2010, 09:04:30 PM
Read 896 times
fannydunker222
1970 fb problems
« on: August 30, 2010, 09:04:30 PM »
ok i just slapped a new deck in the "fannydunker " and need a way to fasten my console down it sits one inch off the deck because of my tank and custom t op any sugestions
steve k
August 31, 2010, 09:23:23 AM
Re: 1970 fb problems
« Reply #1 on: August 31, 2010, 09:23:23 AM »
Not sure what you are describing. Post some pics, It will make it easier for everyone to throw their two cents in!
Mine sits on what looks like a piece of vinyl molding. Then the console is screwed down into it through the flange. I don't think its original but it works. What I have seen, most hulls used a piece of teak.
August 31, 2010, 10:10:23 AM
« Reply #2 on: August 31, 2010, 10:10:23 AM »
manufacture appropriate width strips of 1" polypropylene or starboard material, countersink 1/4-20 flatheads with fender washers/nuts under the deck, then attach your console to the flange in the same fashion, going all the way through, (pretty much what Lew said) do you have a pie hole under the console to get your hands under the deck and work?  Or is there not enough room between the tank and the deck??
