Author Topic: 25 inch shaft  (Read 902 times)
August 25, 2010, 10:22:20 AM
Read 902 times
miky2884
25 inch shaft
« on: August 25, 2010, 10:22:20 AM »
Does anyone know on here if a 25 inch shaft motor will work on my 2001 215 aquasport explorer? My current motor is a 20 inch shaft, i am looking at a possible re power and the motor i am looking at is 25 inch, any info would be greatly appreciated thanks in advance!
August 25, 2010, 10:29:18 AM
Re: 25 inch shaft
« Reply #1 on: August 25, 2010, 10:29:18 AM »
Quote from: "miky2884"
Without going to a jack plate, 5" is just too much difference...
You could use the 4" non-adjustable jack plate like T-H makes...
http://www.thmarine.com/product.cfm?PRID=22
August 25, 2010, 10:40:50 AM
miky2884
Re: 25 inch shaft
« Reply #2 on: August 25, 2010, 10:40:50 AM »
thanks bob i knew you would come through  :wink:
August 25, 2010, 11:38:32 AM
Re: 25 inch shaft
« Reply #3 on: August 25, 2010, 11:38:32 AM »
WOW a 20" shaft on a 215?  That seems REALLY short to me.  Is that on a bracket or is the transom just that low?
August 25, 2010, 12:00:55 PM
Re: 25 inch shaft
« Reply #4 on: August 25, 2010, 12:00:55 PM »
Quote from: "wingtime"
That's exactly what I was thinking.... I would have thought a boat that big would be a 25"
August 25, 2010, 12:02:51 PM
Re: 25 inch shaft
« Reply #5 on: August 25, 2010, 12:02:51 PM »
Wing,
That does seem kind of odd, but remember the boat does have a transom cutout.  20" shaft motors do cost the OEMs less, and Genmar was no novice at trying to save money wherever they could...
August 25, 2010, 12:27:17 PM
miky2884
Re: 25 inch shaft
« Reply #6 on: August 25, 2010, 12:27:17 PM »
i thought the same thing but i searched the specs on my current motor and it says its a 20 in, i thought for sure it would have been a 25
August 25, 2010, 04:37:36 PM
Re: 25 inch shaft
« Reply #7 on: August 25, 2010, 04:37:36 PM »
Wow there are times when I think my transom is low.  I can't imagine a 5" lower opening.  Then again the V of the hull could be different.  Just get out a tape measure and measure from the top of the cutout to the bottom of the V.  It should be well  20"  LOL.
Seabob does the 2001 215 have a Wellcraft sister in a different dress?
August 25, 2010, 05:55:11 PM
Re: 25 inch shaft
« Reply #8 on: August 25, 2010, 05:55:11 PM »
WC 210 Coastal
August 25, 2010, 06:38:40 PM
Re: 25 inch shaft
« Reply #9 on: August 25, 2010, 06:38:40 PM »
Quote from: "Capt. Bob"
WC 210 Coastal
Absolutely right, CB.  They even badged one for a show with AS graphics on one side, WC on the other...
The 2 boats were absolutely identical, except for the upholstery...
August 25, 2010, 06:44:08 PM
Re: 25 inch shaft
« Reply #10 on: August 25, 2010, 06:44:08 PM »
I looked at some pics of 215s from that vintage and they looked like they had 25 inch motors.  Ads for one said it had a Mercury EXLPTO - that would be a 25" motor.
Are you sure it's a 20"?    :scratch:
August 25, 2010, 07:29:51 PM
Re: 25 inch shaft
« Reply #11 on: August 25, 2010, 07:29:51 PM »
All have me really thinking right now.  Typical boats the size of a 215 Explorer will have 25" shafts.  Yet, I'm sure Micky has done the research on his S/N, which Evinrude's database says is a 20" shafter.  So who's to say the mid-section wasn't swapped out in the previous owners life to a 25"?  Drive shaft, shift shaft, and mid-section cowling, and, viola, a 25" from a 20"...
Hmmmm......
August 26, 2010, 12:59:04 PM
Re: 25 inch shaft
« Reply #12 on: August 26, 2010, 12:59:04 PM »
I was thinking the same thing.  I just swapped mid sections on my merc converting it from a 20" into a 25" Frankenmerc.   The serial number on my bracket says it is now a 2001 motor  :roll:     My power head is a 97 and who knows what the lower unit is...  LOL
August 26, 2010, 02:21:40 PM
Re: 25 inch shaft
« Reply #13 on: August 26, 2010, 02:21:40 PM »
The 1997 catalog lists the 215 EX but not the transom height.
The 2000 catalog lists the 215EX with a 25" transom height.
The 2005 catalog does the same.
Just a thought.
August 26, 2010, 03:20:50 PM
Re: 25 inch shaft
« Reply #14 on: August 26, 2010, 03:20:50 PM »
Just a thought.
And a very good one at that...
