Author Topic: gas tank vent where is it ?  (Read 883 times)
August 25, 2010, 01:30:07 AM
Read 883 times
fishingdave
« on: August 25, 2010, 01:30:07 AM »
i have an 05 explorer  and it doesn't seem to have an external gas tank vent. Do they use some type of special  gas cap?
2005 aquasport 225 explorer
2005 Yamaha 200F
August 25, 2010, 10:01:52 AM
Re: gas tank vent where is it ?
« Reply #1 on: August 25, 2010, 10:01:52 AM »
Quote from: "fishingdave"
Back in my day, the Explorers had a separate vent mounted in the hullside just below the fill.  I bet they cheapened up and went with the fill/vent combination.  You should have an access pie in the inwale right by the fill.  Pull that off and see if the vent hose is attached to the fill...
August 25, 2010, 11:10:02 AM
miky2884
« Reply #2 on: August 25, 2010, 11:10:02 AM »
mine is on the cap , i don't not have a vent anywhere in the hull
August 25, 2010, 11:33:48 AM
Double Trouble
  • NorthEast
« Reply #3 on: August 25, 2010, 11:33:48 AM »
Mine is also in the fill atleast you dont have to worry about water getting in.
August 25, 2010, 01:56:47 PM
« Reply #4 on: August 25, 2010, 01:56:47 PM »
ditto
