Thanks for the quick response. Unfortunately i dont have a voltmeter...Ill check all that stuff though, and fuses on the powerhead...u mean under the actual engine cover?Thanks.
Gotime,Here are two wire diagrams for a 89 150. I wasn't sure if you have the 9 amp or 35 amp so I posted a link to either one. In the lower left is the diagram for the switch. If you follow the red wire with the purple trace you will find a fuse. Check that out. That red wire with the purple trace supplies the power for your key switched accessories such as your instruments. Good luck!http://www.maxrules.com/graphics/omc_pi ... 175_9A.jpghttp://www.maxrules.com/graphics/omc_pi ... 75_35A.jpgAlso here is a link to the color code for OMC:http://continuouswave.com/whaler/refere ... e.html#OMCAnd to the key switch:http://continuouswave.com/whaler/refere ... witch.html
You guys nailed it. Red wire, purple stripe...fuse blown in engine. I ended up getting a voltmeter and tracing it back to that wire. Couldnt believe that small fuse in that bunch of wires caused this problem, and a seatow. Oh well...shame on me. Anyway, found that and now keep a bunch of those fuses on the boat. Just kinda curious as to why it would of blown?? Wish i didnt do all the work/searching i did before checking that, but i guess ill know where to look next time. Thanks a ton guys!!
