Author Topic: Fresh water tank  (Read 4087 times)
April 06, 2011, 04:27:16 PM
Re: Fresh water tank
« Reply #15 on: April 06, 2011, 04:27:16 PM »
:thumright:
April 07, 2011, 11:51:32 AM
Glock Diver
« Reply #16 on: April 07, 2011, 11:51:32 AM »
It fits!
 :cheers:
Checked it this morning, and the 11 gal. tank fit into the hatch, once I removed the entire hatch frame.  Pete, if you still are thinking of upgrading your tank, they sell these tanks for $4/gal at MCL.  This one was $44.
But since you're already set up, it might be easier for you to just add a 2nd tank (the 6-gal tank is only $24), and add some T's, to give you the extra capacity.
April 07, 2011, 12:28:18 PM
« Reply #17 on: April 07, 2011, 12:28:18 PM »
Thats great news Mike!It won't be long before you are enjoying nice fresh water showers after diving!Bring along some body wash! :cheers:  :salut:  :thumright:
April 07, 2011, 01:31:26 PM
« Reply #18 on: April 07, 2011, 01:31:26 PM »
Mike, good deal!
Glad it worked out!
I'd like to thank you for taking and sending the pics you took at MCL...Looks like you found exactly what we needed :thumleft:
 :cheers:  :cheers:
April 07, 2011, 02:21:27 PM
Glock Diver
« Reply #19 on: April 07, 2011, 02:21:27 PM »
Mike, good deal!
Glad it worked out!
 :cheers:  :cheers:
You know, if you're restoring an Aqua, MCL also has the big AQUASPORT decals, about 4' long, for the sides. Doubt it would have been standard on your model year but still pretty cool.
April 23, 2011, 09:44:14 PM
Glock Diver
« Reply #20 on: April 23, 2011, 09:44:14 PM »
SUCCESS!
Got everything hooked up today, and it works well.  I opted to place the nozzle up front, where we usually gear up/down.  Got a little creative--  I cut a pie plate, then cut out the cover and placed the shower inside the pie cover!  Got some decent water pressure too.
My only issue is that the tank is slow to fill, because the hose has flattened somewhat below the deck. It's a 1.5"  flexible PVC hose, with the braided things interwoven to keep it open, but maybe I need a different type of hose?
April 23, 2011, 10:13:59 PM
« Reply #21 on: April 23, 2011, 10:13:59 PM »
Mike,
Is it backing up on you through the fill hose?  I other words, if you stick a hose in the fill and turn it on (normal city water pressure), does it shoot back at you?  You may have a vent issue...
April 24, 2011, 10:24:47 AM
Glock Diver
« Reply #22 on: April 24, 2011, 10:24:47 AM »
Mike,
Yes, it will shoot back if I turn the hose on full blast.  But the vent hose is fine.  I can actually feel the kink (not really a kink, but a flattened part) of the large 1.5" hose. So I might need to use a different type of hose....
April 24, 2011, 07:19:30 PM
« Reply #23 on: April 24, 2011, 07:19:30 PM »
Mike,
I attach about a 3 foot length of garden hose with the end cut off and slide it down the pipe and just let it fill.If you have it filling close to the opening some of the water will get into the vent and cause it to back up.Nice install,by the way,hope you enjoy it this summer.Bring along a bottle of body wash to shower up with. :cheers:
April 24, 2011, 11:19:52 PM
Glock Diver
« Reply #24 on: April 24, 2011, 11:19:52 PM »
Thanks Pete I will try that.
Hoping to get out Friday and do some diving on the submerged towers off Sanibel... Will get a chance to use the shower!  Although I'm starting to think I shoulda got 2 water tanks... With a 3.5 gpm pump, my 11 gallons will be gone in 3 mins! Shower quick, lads!
August 04, 2011, 10:17:00 AM
icemanbryan
« Reply #25 on: August 04, 2011, 10:17:00 AM »
So then with the water tank there in the hatian hatch you cant use the storage any more?
Is there another place to mount the water tank?
Bryan
August 04, 2011, 11:50:13 AM
« Reply #26 on: August 04, 2011, 11:50:13 AM »
you can put the tank where ever you want.may be in the console,that would be easy to hook up.the hatian hatch is where they put it at the factory :cheers:
August 04, 2011, 12:33:18 PM
« Reply #27 on: August 04, 2011, 12:33:18 PM »
Quote from: "pete"
That's true.  But the Haitian hatch on a 245 is pretty big, plus you have that center storage on the casting deck that is a lot bigger than Pete's 225...
August 04, 2011, 03:09:44 PM
« Reply #28 on: August 04, 2011, 03:09:44 PM »
yep, lots of places on those boats to put a fresh water tank :cheers:
August 04, 2011, 09:24:09 PM
« Reply #29 on: August 04, 2011, 09:24:09 PM »
here a solulion to mounting a fresh water system,this is a self contained fresh water shower you just plug into 12v,
http://bigkahunashowers.com/   :salut:
