Author Topic: Making a parts run....  (Read 2796 times)
August 16, 2010, 07:46:16 AM
Re: Making a parts run....
« Reply #15 on: August 16, 2010, 07:46:16 AM »
the striping is $25.00 per 150' roll, I looked at it closely last night, it is not the exact dup of what you have, but the width is the same and the colors are all there, just some different widths of each color, there were so many rolls of striping it hurt your brain to try and differentiate between them all.  I think I got the last two TM stickers, they had plenty of the teal green "Aquasport" vinyl that would go on the aft sides of the boats, but they only had one of the gold colored ones, that would go on the TM model.  I am not 100% sure I am going to use the TM stickers, I'll let you know...
August 16, 2010, 03:02:31 PM
« Reply #16 on: August 16, 2010, 03:02:31 PM »
you should definately put the TM logos on they look great,they go right in the center of the hull about even with the CC.  :thumleft:  :thumright:
August 31, 2010, 05:39:59 PM
« Reply #17 on: August 31, 2010, 05:39:59 PM »
After hearing about Marcs' good luck I made a trip down to Marine Connection today!It was a good time they have alot of stuff for the genmarian Aqs. They even had an exact double of my leaning post...$995!I guess if you want it bad enough,they did have alot of wellcraft and Aq pinstriping and lettering,small aq stick on badges,like the ones they put on the seats and bolsters,be prepared to spend 2-4 hour there.I found a roll of pinstriping to replace the sun damaged one on my gunnels as well as this stuff.....
this is the tag off a piece of canvas I found in a dump bin
it is the original canvas to make sort of a cabin out of the console,a portapot goes in there {for the ladies}
I was amazed to find this little treasure in a dump bin $20!The canvas was the same gray color as the console enclosure,they also have some random wellcraft and aq windows for hardtops $10,however they are in a big bin all mixed up with other brands,look for the grey stuff
a new sprayer and hose for the freshwater washdown,the old one was tired looking
August 31, 2010, 05:47:47 PM
« Reply #18 on: August 31, 2010, 05:47:47 PM »
One other thing I found was a gauge hole cover ,I have been wanting to remove the "seakey" system that came with the boat,and never worked.Seabob,there was alot of wires that hooked up to the panel,ok just to leave them as is?
also I spoke with the owner about this site,he said he would check it out. :salut:
August 31, 2010, 07:02:49 PM
« Reply #19 on: August 31, 2010, 07:02:49 PM »
Pete,
As long as the wiring for the SeaKey system doesn't interfere with operating the boat, you can just leave them there...just make them look pretty!
Ah, the old "Seat Tent"...I remember when I got my first one in the canvas package from Taylor with the windscreen, I took it out, slipped it on the seat, and said..."You've got to be kidding me..." :lol:
August 31, 2010, 07:41:33 PM
« Reply #20 on: August 31, 2010, 07:41:33 PM »
I may never use it,maybe the wife might,I just couldn't pass up a piece of original factory canvas. :salut:
August 31, 2010, 09:29:31 PM
« Reply #21 on: August 31, 2010, 09:29:31 PM »
Pete
The striping runs from about $14 - $25 (max, the $25 is for brand new 150' rolls.  They did not have any more TM emblems?? I'm on the fence, but leaning towards putting them on.  I will probably wait until I get that wide striping on, and see how it looks.  I want to name her, and not sure if the side will get too crowded with the TM and and a full name on the side?? If I don't use them, their yours if you want them. If you go over there, have a list of things, and measurements of those things, in some areas of the building the stuff is just stacked up, and you really have to know exactly what you are looking for.
August 31, 2010, 09:38:20 PM
Glock Diver
« Reply #22 on: August 31, 2010, 09:38:20 PM »
Quote from: "pete"
I make my wife use the livewell.   :lol:   Does that make me a cold hearted bastard?  I just refuse to have a porta potti on my boat!
August 31, 2010, 11:00:34 PM
« Reply #23 on: August 31, 2010, 11:00:34 PM »
Glock,yes it does,my wife would hold it before using the live well,lol,if anything we'll use a bucket,even if I never use it I just couldn't pass it up.
Marc,l put my boat name on the wide part of the gunnel ,bought a roll of thin striping that goes near the top of the gunnel,marine conn is definately overwhelming,no more logos,just the "cat" ones, saw the panel you bought it looks brand new.hope you put on the logos it will look great with the stripe.
will replace top stripes above boat name
pic shows boat name and TM logo
 :salut:
September 01, 2010, 09:35:52 PM
« Reply #24 on: September 01, 2010, 09:35:52 PM »
You know the saying, "Even a blind squirrel finds a nut once in a while"  last two days, SINCE THE MONSOONS have stopped, I have been working on installing some of the stuff from down south.  Made a new gauge panel from Lexan (painted backside black) came out sweet, pulled the POS Northstar F-210 fuel management harness out, and lubed up the new yamaha FMS harness with Dawn (always on the boat now with the oil thing going on) and I can't believe it pulled right through, that stuffing tube looks like it has more crap in it than a port-o-let at a BBQ festival, but it went... (first nut).
Then this afternoon, I went for the new swtich and CB panel that I got down there, looked the same, but there was one additional brown bilge wire in the square (hot) plug and one additional ground in the ground plug, my figuring (Bob) is that was for a FWD Bilge Pump?? Anyway after adding the couple devices that I have added, and hooking all the plugs up.... EVERYTHING lit off just as advertised!! right across the panel, the only adjustment was on the Nav light switch I had to play around with the hot feeds to get my newly installed T-Top anchor light to come on by itself when in the "anchor" position. (second nut)
No gremlins, no cussing too much, although.... I must believe that the console was wired before installed on the boat... some of those wire tie screw in things were in places where I had to pull muscles I didn't know I had to get them loose, or Genmar had elves doing the wiring  :lol:  :lol: ya'll have a good one.
September 01, 2010, 09:50:58 PM
« Reply #25 on: September 01, 2010, 09:50:58 PM »
sounds like you were busy,would love to see some pics.if you ever need aaything from marine connections let me know ,only an hour away,and it would give me an excuse to go :salut: and I know what you mean on that panel that wiring is tight,not much room to work.
September 01, 2010, 10:05:11 PM
« Reply #26 on: September 01, 2010, 10:05:11 PM »
Marc,
I never used the ty-wraps with the mounting eyes.  Hated those damn things!  Always Adel cushion clamps for me, my boss didn't mind.  The problem is :*: that is wired to the deck or hull before the boat was decked.  Most builders really don't care that the wiring has to be dealt with several years down the road...
I have Alex Buck's (fabuck71) 200 out next to my shop right now. I can attest for that...
September 01, 2010, 10:38:09 PM
« Reply #27 on: September 01, 2010, 10:38:09 PM »
Yeah, I'll get some pics up when I get finished, looks like he-DBL-L under the console right now, but the switch and gauge panels are going to be sweet.  My friend in Jax has an in with a fab shop over there, I sent him the original gauge panel, and he is going to have the guy bust one out of high polished aluminum, when I get that back I'll take some pics, the Lexan may be temporary.  Do you know if the gauge panel on the 245 and 225 ospreys were identical?? we could get some of these made up if they turn out nice?
September 01, 2010, 10:47:49 PM
« Reply #28 on: September 01, 2010, 10:47:49 PM »
Yes they were, even with twins...
September 02, 2010, 03:03:36 PM
« Reply #29 on: September 02, 2010, 03:03:36 PM »
cant wait to see it :salut:
