Hi Ace3,
Your 125 is rated at 5250 rpm max. They make lots of torque but Mercury kept these motors tamed at a lower rpm. You have a 2+2 engine like my 115's. Idles on two cylinders; the other two kick in at 1800-2000 rpms. They are great for trolling and really get some decent fuel economy at idle. You have a 2:07 to 1 gearatio. I`m pretty sure a 15 or a 17 pitch is going to work for you. If your partial to Mercury props, the Vengence is a good all around prop. I really like the Stilletto props and are less expensive than the Mercury offering. Make sure you keep this engine in the 5000-5200 rpm range at full throttle. As for weight, if you have a pre- CCP 22-2; 72-76 they were advertised at 1850# dry weight. Like all of them she has probably put on a little weight since new.
